29376 Discussions
listbox controlö not reacting to \t
Paul_Felz
I am using Intel compiler with Visual Studio in a Windows 11 environment. One of my dialogs, created with the dialog editor of VS has two edit boxes, one is only a single line and provides the headline for the second. Both are created with the same styles with 'accept tabs' included.
With my code (see below) I set the tabs position and create strings wherein the places of the tabs are marked by '\t'. The headline-string works fine, however the strings I compile to enter in the listbox below do not. Though for all Iknow, both strings are identical in terms of deployment of \t and the char(0) at the end.
    iRslt = SendMessage (hControllistHeader, LB_RESETCONTENT, 0, 0)     ! Überschriftzeile löschen
    iRslt = SendMessage (hControllist, LB_RESETCONTENT, 0, 0)           ! Liste löschen
    ! Tabulatore setzen
    iTabs = (/50,80,110,140,200/)                                       ! ergibt jeweils das 1,5-Fache in Pixel!
    iRslt = SendMessage (hControlListHeader, LB_SETTABSTOPS, 4, loc (iTabs))
    iRslt = SendMessage (hControllist,LB_SETTABSTOPS, 4, loc(iTabs))
    cText = 'Ort\tBetrieb\tPNenn [MW]\tBrennst.\tRolle'C
    iRslt = SendMessage (hControllistHeader, LB_ADDSTRING, 0, loc(cText))
    do j = 1, iiNPower
        cText = trim (ttWerke(j).cOrt)                                  ! 'Aalen'
        if (ttWerke(j).lIsOnline) then
            cText = trim(cText)//'\tIn Betrieb\t'
        else
            cText = trim(cText)//'\tStillstand\t'                       ! 'Aalen\tStillstand\t'
        endif
        write (cRslt,'(i4)') int (ttWerke(j).rPNenn)
        cText = trim(cText) // trim(cRslt)// '\t'                       ! 'Aalen\tStillstand\t  15\t'
        cText = trim (cText) // trim (ttWerke(j).cTraeger)//'\t'        ! 'Aalen\tStillstand\t  15\tErdgas\t'
        cText = trim (cText) // trim (ttWerke(j).cRolle)//char(0)       ! 'Aalen\tStillstand\t  15\tErdgas\tHKW'C
        iIndex = SendMessage (hControllist, LB_ADDSTRING, 0, loc(cText))        ! Eintrag hinzufügen
        iRslt = SendMessage (hControlList, LB_SETITEMDATA, iIndex, j)           ! Den realen Index mitgeben
    enddo
I added what I think the string would look like as comments at the end of the lines.
What is wrong? I could not find any reference neither in the intel nor in the VS docs. Any ideas?
Cheers
PF
Steve_Lionel
Are you expecting '\t' to be an actual tab character as it would be in C? It doesn't work that way in Fortran.  You could use ACHAR(9) or C_HORIZONTAL_TAB from intrinsic module ISO_C_BINDING.
I'll comment that small code excerpts aren't useful in diagnosing problems, and to be honest I don't quite understand your description of the symptom.
Paul_Felz
Thanks Steve.
Sorry for my clumsy description here. Take a look at my image: The headline works as it should, that is, the text behind a '\t is printed starting at the next tab.
In the next line, to my understanding in the exact same format in a listbox with the exact same styles (as far as I know that is) the '\t's are printed as if they were ordinary parts of the string and the tabs are ignored.
As far as I know, win32 is coded in C, so I think that is the environment, the '\t should work in, not in FORTRAN.
But I'll try with this ACHAR(9).
Thanks again.
PF
andrew_4619
Sort of what Steve said, but when you have "String\tString2"C the compiler is using and intel extension to treat it in a C way. But in your other instances it is being treated in the Fortran way so use Achar(9) or I think  .....trim (cText) // trim (ttWerke(j).cTraeger)//'\t'C  might work for you.
Steve_Lionel
In your lines 17-19, the \t will NOT be translated to a tab. The one in line 7 will be because it's in a C-string (an extension).
Paul_Felz
Okay, thats it. ACHAR(9) works. So I understand a C-String is not just a FORTRAN-String with a char(0) pasted to the end but something different.
Thanks to all f you.
Cheers
PF
Steve_Lionel
Correct - in addition to the NUL padding, a C-string supports many of the typical C backslash sequences. Again, this is an extension.
