29640 Discussions
redefining a do loop index inside a do loop
andrew_4619
I just spent a while chasing a puzzling bug, and made a simple  code to demonstrate. Clearly it is not legal Fortran  but is is reasonable to expect the compiler to complain (it doesn't)?
program testcontains
    implicit none
    integer :: l1
    do l1 = 1 , 2
        call tester()
        print *,'main',l1
    enddo
    contains
    subroutine tester()
        do l1 = 1, 4
            print *,'tester',l1
        enddo
    end subroutine tester
end program testcontains
The result is:
tester 1
tester 2
tester 3
tester 4
main 5
because l1 is illegally redefined within the do loop. I am unsure if the complier is required to complain or not I guess that depends if there is a specific constrain in the standards.
Declaring L1 as integer within tester() fixes the problem as l1 then becomes local.
Steve_Lionel
No, the standard does not require a compiler to complain about this.  I tried it with NAG Fortrtan and it offered:
Questionable: t.f90, line 10: DO index variable L1 is not a local variable (it is from host TESTCONTAINS)
It would be great if /warn:usage in the Intel compiler would do something similar, but of course that would require you to specify it.
Steve_Lionel
jimdempseyatthecove
Steve,
Something else may be exposed by this simple (ill formed) test program.
The do loop statement (is to) produce a trip count based upon the statement's initial conditions.
Line 4 of the example code should have created a trip count of two (as opposed to a limit test of its scoped l1 <=2).
The resultant code showed  (implied) that a limit test was performed as opposed to a trip count (unless the compiler generated a shared variable/register for use as a trip count, which would also be an error in code generation).
Comments?
Jim Dempsey
Steve_Lionel
The standard says that a DO loop calculates a trip count at the beginning. Any changes to the index variable inside the loop result in undefined behavior. I believe that if the Intel compiler detects a possible modification of the index variable, it switches to a tested loop - at least that was the behavior in the DEC days for compatibility with old code that did this, and from your observation that still seems to be happening. Non-standard code produces undefined behavior.
jimdempseyatthecove
Right about the trip count. The point I was trying to make was that, the output of the test program shows the printing of "main ..." once, not twice as the trip count would perform. While the code is expected to have undefined behavior, I suspect that the missing trip count run is indicative of a different problem, which should be looked at.
Jim Dempsey
Steve_Lionel
There is no problem with the compiler - it is behaving as designed. It sees that there is a procedure call in the loop which could potentially modify the index variable, and then changes to a tested loop.
I wrote about the perils of unexpected uplevel references at Doctor Fortran in "Think, Thank, Thunk" - Doctor Fortran (stevelionel.com)
