29279 Discussions
'loc' is not an array, a dumb question
wu_internet
I've got a dumb question here, normally I can use the LOC(XX) function to determine the address of the variable XX in the immediate window during debug, However, this time when I am doing the debug, no matter in the watch window or immediate window, it reports that 'LOC' is not an array, it just does not give me any answer about the address anymore. If I try with a small application, it seems alright. anymore have similar kind experience or you konw why it happened, please help.
David.
sabalan
Check if you have declared or used LOC as some variable in your code.
Sabalan.
wu_internet
It is the case, thanks a lot.
Rgrds,
David
