machine precision -- smooth region
diedro
hi everyone,
I'ma writing a code about diffusion. It is veru sensible to fortran precision. I men negative value (taht I do not want) star from -1.e-60 and than rise ud to 1.e2.
I compile in double precision. Hos is possible that the program can handle so negative errors, Can I set them to zero when I compile.
Really really thanks
Anonymous66
Valued Contributor I
The option, -fpe1 will turn on underflow to zero rather than allowing gradual underflow. Any value that is too small to be represented precisely in double precision will be rounded down to 0. Is something like this what you are looking for?
diedro
yes is that the things that I want to know. However I got the same error. Do you know a forum where to talk about numerical scheme problem? thanks a lot
Anonymous66
We do not have a forum specifically for numerical scheme problems. This white paper may be useful to you though.
Ron_Green
jimdempseyatthecove
diedro wrote:
hi everyone,
Try changing your parameters and literals from "e" to "d". Example, change -1.e-60 to -1.d-60 "e" defaults to REAL(4) Jim Dempsey
TimP
In case the implication of changing from a single to a double precision constant isn't evident, the smallest magnitude non-zero single precision numbers are TINY(1.)*EPSILON(1.) when gradual underflow is enabled, and TINY(1.) in the case of abrupt underflow (ifort option -ftz). In either case, 1.e-60 is the same as 0. (except possibly in some contexts of -mia32)
