29653 Discussions
memory leak of function returning polymorphic allocatable with allocatable components
Emil_S_
The following code results in a memory leak when compiled with ifort 14.0.3
module testmod
  type :: obj
     integer, allocatable :: i
   contains
     procedure :: add => obj_add
     procedure :: copy => obj_copy
     generic :: operator(+) => add
  end type obj
contains
  subroutine obj_copy(this, source)
    implicit none
    class(obj) :: this
    class(obj) :: source
    this%i=source%i
  end subroutine obj_copy
  function obj_add(A, B) result(C)
    implicit none
    class(obj), intent(in) :: A, B
    class(obj), allocatable :: C
    allocate(C)
    allocate(C%i)
    C%i=A%i+B%i
  end function obj_add
end module testmod
program leak
  use testmod
  implicit none
  class(obj), allocatable :: A, B, C
  allocate(A, B, C)
  A%i=1
  B%i=2
  call C%copy(A+B)
  deallocate(A, B, C)
end program leak
When compiled with
ifort -g -o leak leak.f90 -assume realloc_lhs
Valgrind reports
==21260== 4 bytes in 1 blocks are definitely lost in loss record 1 of 2
==21260==    at 0x4C2B3F8: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
==21260==    by 0x419BF8: for_alloc_allocatable (in /mnt/data/PhD/Fortran/bugs/operator-leak/leak)
==21260==    by 0x402F41: testmod_mp_obj_add_ (leak.f90:26)
==21260==    by 0x403431: MAIN__ (leak.f90:39)
==21260==    by 0x402BC5: main (in /mnt/data/PhD/Fortran/bugs/operator-leak/leak)
 think this might also be the cause of the problems encountered in this thread https://software.intel.com/en-us/forums/topic/487142 from some time ago.
If I change the result dummy to
type(obj) :: C
and skip the allocation stuff in obj_add, then the leak is avoided. However, this also results in losing polymorphism, which is undesirable. If the procedure is made as a subroutine, I lose the ability to use it as an operator. Does anybody have any suggestion to work around this issue?
Best regards
Emil Sørensen
Kevin_D_Intel
I will investigate this issue Emil and post an update shortly.
Kevin_D_Intel
I reproduced your findings and see the same results for newer compilers and reported this to Development (see internal tracking id below) for further investigation. I will update the post with information about any work around and status as I learn it.
(Internal tracking id: DPD200358323)
Emil_S_
Thank you very much Kevin, I appreciate it. This leak has really proven to be a show-stopper for my implementation.
FortranFan
Emil,
Would you be interested in running your code example through Intel Inspector for Linux (if you don't have a license, you can check with Intel staff about being getting a free evaluation license to their 2015 BETA version) and see whether it can catch the same memory leak that Valgrind found?  If yes, I'll be interested in learning from your findings.
Emil_S_
Hi FortranFan
I am unfamiliar with the Intel Inspector, but I have downloaded an evaluation copy of Intel Inspector XE 2013 and gave it a try. This is what I obtained
$ inspxe-cl -version
Intel(R) Inspector XE 2013 Update 9 (build 328075) Command Line tool
Copyright (C) 2009-2013 Intel Corporation. All rights reserved.
$ inspxe-cl -collect mi3 -knob analyze-stack=false -knob detect-leaks-on-exit=true -knob enable-memory-growth-detection=true -knob enable-on-demand-leak-detection=true -knob remove-duplicates=true -knob still-allocated-memory=true -knob stack-depth=16 -module-filter-mode=include -appdebug=off -- /mnt/data/PhD/Fortran/bugs/operator-leak/leak
1 new problem(s) found
    1 Memory leak problem(s) detected
$ inspxe-cl -report problems -result-dir r000mi3/
P1: Error: Memory leak
 P1.3: Memory leak: 4 Bytes: New
  /mnt/data/PhD/Fortran/bugs/operator-leak/leak.f90(26): Error X3: Allocation site: Function obj_add: Module /mnt/data/PhD/Fortran/bugs/operator-leak/leak
So as far as I can tell, Intel Inspector finds the same memory leak as Valgrind did.
FortranFan
Thank you very much - greatly appreciate your post.  I'll follow-up on my installation of Intel Inspector and check why I don't get the same response.  By the way, I work mainly on Windows platform (our sole Linux box has been unavailable for a while) and am experiencing similar issues with memory leaks with user-defined operators in Fortran 2003/2008 code.  I've been playing around with Intel Inspector on Windows 2015 Beta since Valgrind is unavailable on Windows; I'm not having much luck with Inspector finding leaks even though Dr. Memory (another tool) says there are leaks.  Hence my request to you to do the checking with Inspector on Linux.
Emil_S_
No problem FortranFan, glad I could help :)
