hello
i have a c++ native code run in 32 bit,i want migrate in 64 bit with no changes in code and without any recompilation
is it possible,if it is,how?
tnx
tnx
If you have all required 32-bit run-time libraries visible on LD_LIBRARY_PATH, the program should run OK, or even slightly better, on the 64-bit installation.
