29271 Discussions
mixed C/Fortran linking problems with ifc 7.1
mustafaatlihan
I am able to build my application, which is a mixed C/Fortran application, on windows without problems using icl and ifl (7.1)
However, when I port the source code to Linux, I cannot have my C functions linked to the Fortran objects. Below is small mixed C/F9x application that illustrates what I experience in my original application.
There is a "main.for" which calls a C function (fact.c) to compute the factorial of an integer.
When linking the objects with ifc 7.1, I get the following error.
$> ifc src/main.o src/fact.o -o src/fact -lcxa -C90
src/main.o(.text+0x20): In function `main':
: undefined reference to `FACT2'
Here are the files. My linux box is RH 8.0. Any help would be truly appreciated. Note, the function name in fact.c is (deliberately) aliased and made uppercase.
C-- file 1: main.for --
CCCCCCCCCCCCCCCCCCCCC
MODULE CFACT
INTERFACE
INTEGER FUNCTION FACT( N)
!MS$ ATTRIBUTES C,ALIAS:'FACT2'::FACT
INTEGER N [REFERENCE]
END FUNCTION FACT
END INTERFACE
END MODULE
CCCCCCCCCCCCCCCCCCCCCC
program main
use CFACT
implicit none
integer f1,f2,f3
f1 = FACT(10)
write (*,*) 'fact = ', f1
stop
end
/**** file 2: fact.c *****/
int FACT2( int *n)
int i, f = 1;
for (i=1;i<=*n;i++) f = f * i;
return f;
TimP
It looks like you are running into the difference between the usual Windows and linux Fortran link symbol mangling. ifc uses lower case symbols with appended underscore.
For example, you might build your C file like:
icc -DFACT2=fact2_ -c src/fact.c
The linux utility,which you could use to examine your .o files for comparison of link symbols is nm
nm *.o
somewhat similar to Windows
dumpbin /symbols *.obj
mustafaatlihan
Thank you. You suggestion solved the issue.
MA
