mixed relational expression
tracyx
ifort (11.0.083) compiles without error if I have a mixed relational expression of the form,
if ('abc'==5) then...
how does ifort treat such expressions? i could not find any discussion in the documentation. should this raise an error?
It's historical. For character literals 4 characters or less they are treated as if they were Hollerith constants (e.g. 3Habc), which are integers.
TimP
Quoting - tracyx
Apparently, 'abc'==5 is evaluated to .false. at compile time. If you set -stand, you get the mandatory warning according to standard (at least in current versions). This is a weird extension, not supported by many other compilers.
tracyx
Quoting - tim18
Thank you for your reply. I had some code which had an expression like this (in error), and only spotted it when I ran it through g95.
This seems a bizarre (and potentially dangerous) extension. Apparently 'abc'>5 is true for some reason.
TimP
Compilers I used in the past went the other way, treating Holleriths as CHARACTER, in contexts where they weren't permitted in f66, and so aren't covered by standards.
