mkl compile problem
hay1987
helo; i'm new in using fortran
so wrote my prog like this :
include 'mkl_vsl.f'
MODULE mod_nonlinear_solver
use .......
use .......
IMPLICIT NONE
CONTAINS
USE MKL_VSL_TYPE
USE MKL_VSL
implicit none
END MODULE mod_nonlinear_solver
so it sent to me this error message :
1
Severity Code Description Project File Line Suppression State
Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MOD_NONLINEAR_SOLVER] C:\Users\Desktop\empirical work\\model.f90 13
2
Error error #6404: This name does not have a type, and must have an explicit type. [VSL_METHOD_SGAUSSIAN_ICDF] C:\Users\Desktop\empirical work\\mod_nonlinear_solver.f90 114
i think that the compiler don't see the floder of mkl lib despite i think that i make the necessary connection at the property of my app
please help me
thanks
mecej4
Your code was probably written for a much older version of MKL. It would have helped if you had stated which version of MKL you are using now.
Look up the VSL documentation for your version of MKL, and modify the code to match the specification of the routine. For the current version of MKL (2020.2), you can view the documentation , and see that you should probably replace VSL_METHOD_SGAUSSIAN_ICDF by  VSL_RNG_METHOD_GAUSSIAN_ICDF .
mecej4
hay1987
thank you very much
