29376 Discussions
mkl95_LAPACK produces segmentation fault (dgesv)
zuch
When I call  "dgesv" routine from mkl library with fortran 95 interface I get segmentation fault.
call dgesv( adns, rhs , ipiv , info ) ! forrtl: severe (174): SIGSEGV, segmentation fault occurred
call dgesv( n, nrhs, adns, max(1,n), ipiv, rhs, max(1,n), info )  ! F77  works fine
ifort -V
Intel(R) Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 14.0.2.139 Build 20140121
Copyright (C) 1985-2014 Intel Corporation.  All rights reserved.
compiler flags: ifort main.f90 -mkl -lmkl_lapack95_lp64
mecej4
If you wish to call the F95 generic name, which is the one with optional arguments, use the generic name, gesv, and not the specific name, dgesv, and make sure that you have provided the necessary interface (by including USE MKL95_LAPACK in every routine that calls a Lapack95/Blas95 routine by its generic name). The fact that you ran into a seg-fault indicates that your code does not contain such an interface, causing the subroutine to be called with mismatched number/types of arguments.
If you wish to call the F77 specific name, dgesv, provide all the arguments specified in the argument list for the subroutine.
zuch
Thanks! I've missed that. now it works
