29233 Discussions
mpi is not recognized when I compile the Fortran code.
FeiYa
I've installed the Fortran compiler and mpi lib. When I use commands 'which ifort' and 'which mpirun' to check, it shows the correct direction where I installed it.
However, the 'mpi' still can not be recognized when I compile the code.
Can you tell me how to solve this problem?
