I don't have C compiler for IVF XE 13. Can somebody please share their binary version of netcdf library for 64 bit version for windows 7 using IVF XE 13?. I need this very badly to run large ocean circulation model. My previous versions were all 32 bit and I need 64 bit.
Thanks for your help,
Venkat
It would help if you let everyone know which NetCDF version you are looking for. You can check this page for more info: http://www.unidata.ucar.edu/downloads/netcdf/index.jsp
Thanks for your reply. I temporarily used 3.6.2 version on 64 bit machine and get the phase 1 of the project completed. However, I need version 4.4.1 for phase 2 of my project. I only have intel fortran compiler XE 13 and don't have c compiler to do run make file included elsewhere in the intel website. If any one has done compiled and made new library for 4.4.1 or any version around 4 series, can you please share it with me and others.
This will also help others.
Venkat
Microsoft has made available Visual Studio 2013 Community Edition, for free, which includes C++. You can use this with Intel Visual Fortran (for the 2013 version, you need "SP1 Update 1" at least.)
Thanks Steve,
I installed Visual Studio 2013. But I have installed XE 2013 SP 1 on visual studio 2010. How do I make connection between the two?
Do I need to reinstall Composer 2013 XE on visual studio 2013?
Venkat
Run the Fortran installer again and do a "Modify" - it will allow you to select VS2013 integration.
