29487 Discussions
new versions of svml give different results that older versions for many math functions
gn164
Consider the following code as an example
version 14.0 of svml calculates the sin(90) as 1 while latest svml  calculates it as 0.99999.
This can obviously create problems if subsequent calculations rely on the sin result  to be exactly one.
Could someone please advice what is the best way to deal with these roundoff errors in newer versions of the libraries.
program sum
    real angle_degrees(100)
    real angle_radians(100)
    pi = 4 * atan (1.0_4)
    pi180 = pi/180.0
    angle_degrees = 90
    angle_radians = sin(angle_degrees * pi180 )
    print * , angle_radians
end program sum
Juergen_R_R
Valued Contributor II
This is the usual issue with floating point numbers. For floating point numbers you should never test for exact equality
but for equality within a given precision. E.g. something like the code below. Check the documentation on the flags for the numerical models in order
to look what the exact behavior is.
  elemental function nearly_equal_real (a, b, abs_smallness, rel_smallness) result (r)
    logical :: r
    real(default), intent(in) :: a, b
    real(default), intent(in), optional :: abs_smallness, rel_smallness
    real(default) :: abs_a, abs_b, diff, abs_small, rel_small
    abs_a = abs (a)
    abs_b = abs (b)
    diff = abs (a - b)
    ! shortcut, handles infinities and nans
    if (a == b) then
       r = .true.
       return
    else if (ieee_is_nan (a) .or. ieee_is_nan (b) .or. ieee_is_nan (diff)) then
       r = .false.
       return
    end if
    abs_small = tiny_13; if (present (abs_smallness)) abs_small = abs_smallness
    rel_small = tiny_10; if (present (rel_smallness)) rel_small = rel_smallness
    if (abs_a < abs_small .and. abs_b < abs_small) then
       r = diff < abs_small
    else
       r = diff / max (abs_a, abs_b) < rel_small
    end if
  end function nearly_equal_real
jimdempseyatthecove
Juergen,
Three points:
1) the epsilon function should be used in combination with the magnitudes of the input arguments such that the precision takes into account of these magnitudes.
2) ieee_is_... intrinsic functions have significant overhead, if possible perform what you can before making these tests.
3) While one NAN is not equal to one not-NAN, two NAN's are neither equal nor unequal
Jim Dempsey
Juergen_R_R
Thanks, Jim. Our definition of "tiny" contains the epsilon function: real(default), parameter, public :: & eps0 = epsilon (zero), & tiny_13 = 1E3_default * epsilon (zero), & tiny_10 = 1E6_default * epsilon (zero), & tiny_07 = 1E9_default * epsilon (zero) Furthermore, we do test runs with signalling NaNs for our software, so that the test for NaNs in this float comparison function is rather academic. But most definitely thanks for the remarks.
jimdempseyatthecove
Oops, strike 1), the r = diff... should be sufficient to take into consideration the magnitudes verses precision.
Jim Dempsey
jimdempseyatthecove
But then these are relative to 1E3, 6 and 9. When you have numbers of much larger (e.g. astronomical scale) or smaller (atomic scale) then the magnitude of your tiny(s) must be futzed with. You might want to consider
tiny = min(a,b) * epsilon(zero) * YouPickNumberRelativeToLSB (e.g 2, 4, ...)
Jim Dempsey
