29429 Discussions
Add a path by name to visual studio additional xxx directories
pascal_M_
I have added `C:\path\to\files\thelibrary\include` to the `Configuration Properties --> Fortran --> General --> Additional Include Directories`, and used an `#include <someheaderfile.h>` inside my code, and everything was compiling as intended. Now I have created a sytem environment variable `TOTO` with value `C:\path\to\files\thelibrary` and replaced `C:\path\to\files\thelibrary\include` with `%TOTO%\include` inside `Configuration Properties --> Fortran --> General --> Additional Include Directories` and at compilation I had an `#error: can't find include file: someheaderfile.h`. I also tried with `%(TOTO)\include` and `%TOTO%\include` as well as `TOTO\include` and had the same error. I don't know though if this error is specific to the fact that I am inside a intel visual fortran project for visual studio or if I would have had the same issue with a vanilla c++ visual studio project.
Of course, I have the same issue with "additional libraries" etc.
Lorri_M_Intel
After you defined the system environment variable, did you exit/restart your Visual Studio window?  Not just reload the Fortran solution, actually exit out and restart Visual Studio.
And, no, this isn't just a Fortran-integration thing.   I've seen this sort of thing with pure C/C++ projects too.
                  --Lorri
pascal_M_
                  --Lorri
I even rebooted the d*** computer. :) One precision though : the problem does happen with the (system) environment variable I have created, but doesn't with using the environment variable IFORT_COMPILER19 in `%IFORT_COMPILER19%mkl\lib\intel64_win` for instance.
pascal_M_
Other precision : I confirm that this doesn't happen with a vanilla (c++ console for instance) visual studio 2017 project, nor with intel visual fortran console project. (My project type, with which I have a problem, is "intel visual fortran dll project".)
Steve_Lionel
The syntax you want is $(TOTO)
pascal_M_
As I wrote in my question, I "did" try $(TOTO) and it didn't work ... Anyway, now it worked. (Strange, maybe I mixed up things.)
Question, though : why does %TOTO% work for a fortran console project but not for a fortran dll project ?
Steve_Lionel
I would not expect %TOTO% to work in either. Certainly the project type doesn't matter. The %TOTO% syntax works in a shell command,but not in the list of additional include directories.
What I have seen sometimes is that setting system environment variables don't "take" right away, sometimes needing a logout/login.
pascal_M_
Well `%IFORT_COMPILER19%mkl\include` is understood without problem any though.
Yes, same for me, I was never clear on that.
