norm2 for complex vectors
diedro
dear all,
I usually use NORM2 to compute the error in a while cycle.
However, I have complex vector now and NORM2 does not work.
Is there any norm2 function for complex vectors?
mecej4
There is a routine NRM2 in MKL, of which the flavors SCNRM2 and DZNRM2  pertain to complex vectors. There is an overloaded routine NRM2 available through the F95 interface.
Not in the Fortran standard - NORM2 is defined for REAL only.
diedro
Dear all, Dear Steve,
Ok. Do you have some suggestion to overcome this?
this is my code, I use norm2 to compute the error:
 DO WHILE(NORM(R1)>=eps*NORM(BBg))
        P1 = R1 + beta0*P0
   ENDDO
where R1 and BBg are complex vectors
Thanks for any help
TimP
You'd have to specify explicitly how you want NORM calculated.
mecej4
JVanB
Valued Contributor II
I can't understand at all why NORM2 for complex input isn't in the standard. Stuff like NORM2(transfer(x,[real(kind(x))::])) or NORM2([NORM2(real(x)),NORM2(aimag(x))]) is possible.
diedro
Dear all,
thanks a lot.
NRM2 and NORM2([NORM2(real(x)),NORM2(aimag(x))]) work for me.
I have only to compute the difference between two complex vectors
thanks again
