odd problem
lklawrie
Large project -- getting an access violation with certain compiler settings.
If try to put it in debugger or add any checks (i.e. array bounds, etc), it runs.  Adding /fpe:0 and it runs.
I'd like to say it's a compiler issue but?
lklawrie
Steve is looking at it -- including the assembler from the module that is showing the access violation.  He called it "odd" as well.
It's defying easy analysis, I can tell you that much.... But I CAN reproduce it with a build from sources, so that helps...
