odd problem
lklawrie
Large project -- getting an access violation with certain compiler settings.
If try to put it in debugger or add any checks (i.e. array bounds, etc), it runs.  Adding /fpe:0 and it runs.
I'd like to say it's a compiler issue but?
lklawrie
"faulting ip"?  Please be clear in what you are requiring/suggesting.  And why is it fine in Win32 but not x64?
Different architectures mean different memory layout, different instructions, etc. "faulting IP" means the instruction pointer of where the error occurred. Technically, you have that already as its in the traceback.
So now we know that the source line of the error is:
  5409              FinalZoneSizing(CtrlZoneNum)%CoolZoneRetTempSeq(TimeStepIndex) = &
   5410                FinalZoneSizing(CtrlZoneNum)%CoolZoneTempSeq(TimeStepIndex) + RetTempRise * &
  >5411               (1.d0/(1.d0+TermUnitSizing(CtrlZoneNum)%InducRat))
but we don't know which part of this statement is the problem. realistically, it will be either FinalZoneSizing(CtrlZoneNum)%CoolZoneRetTempSeq(TimeStepIndex) or TermUnitSizing(CtrlZoneNum)%InducRat). What I would do, as an experiment, is declare a temporary variable, say, temp, and assign TermUnitSizing(CtrlZoneNum)%InducRat)) to it before this statement, then substitute temp in the expression. Do you still get the error? Does the error move? If the error still exists but doesn't move, then FinalZoneSizing(CtrlZoneNum)%CoolZoneRetTempSeq(TimeStepIndex)  is probably the problem - you'd have to figure out which part of this is wrong.
lklawrie
There is no longer an error in that case.  now what?  And, as I've said before, if you don't change the statement but print something before it (didn't try printing after) -- the file runs.
If I had the program here, I'd step through the instructions in the debugger to see what it is doing. It's not something I could easily walk you through.
lklawrie
Where would you like me to put it?  I can zip up the object/source/project.  It will be quite large.
I have to backtrack on my previous statement -- it does now terminate where it says:
temp=termunitsizing
I had inadvertently added a "if (allocated(termunitsizing)) stop" statement above that -- and it caused it to run.
maybe i can work with it further.
lklawrie
Still no help -- now inspector says it fails there but the debugger information is not helpful (due to the optimization, I'm sure).
Where would you like a zip file, Steve?
Please use Intel Premier Support and ask that the issue be assigned to me.
Try building with /standard-semantics (Fortran > Language > Enable F2003 Semantics)
lklawrie
I am building with F2008 semantics.  I did manage to get the compiler / debugger to show that the index of that structure was 0 -- however it is inside a specific loop with that index as a loop control variable.
It may take a while to make it so you can see it -- but to me, it seems like a compiler bug.
Bernard
Valued Contributor I
Sorry for not providing enough expalnation.Faulting ip = instruction pointer which caused some fault or exception.
Bernard
Please proceed exactly as Steve advised.Run your program under debugger(first source-level) step in on every instruction and inspect the memory beign read/written pay attention to any pointer dereferences.If this will not be helpful machine code level debugging with the help of application verifier should be used to test your app.
SergeyKostrov
Valued Contributor II
>>...Large project -- getting an access violation with certain compiler settings... Linda, The thread is already 5-day-old and why woudn't you post a complete set of compiler settings for a review?
lklawrie
Issue 698745 posted.  Steve, it's set to run with break at the place where it will most likely crash.
No one asked for compiler settings. Compiler settings:
Compiler:
/nologo /debug:minimal /O2 /module:"x64\Release\\" /object:"x64\Release\\" /Fd"x64\Release\vc90.pdb" /traceback /libs:static /threads /c
pasted to command line window (from others)
/nologo /fpp /stand:f08 /Qdiag-disable:5268 /fpscomp:none /nogen-interfaces /F8388608 /DWINDOWS /O2 /DNDEBUG
Linker:
/OUT:"x64\Release\Console3.exe" /INCREMENTAL:NO /NOLOGO /MANIFEST /MANIFESTFILE:"C:\Users\lklawrie\Documents\Visual Studio 2008\Projects\Console3\x64\Release\Console3.exe.intermediate.manifest" /MANIFESTUAC:"level='asInvoker' uiAccess='false'" /DEBUG /PDB:"C:\Users\lklawrie\Documents\Visual Studio 2008\Projects\Console3\x64\Release\Console3.pdb" /SUBSYSTEM:CONSOLE /IMPLIB:"C:\Users\lklawrie\Documents\Visual Studio 2008\Projects\Console3\x64\Release\Console3.lib" /STACK:8388608
Thanks - I got it. I will get to it soon.
SergeyKostrov
>>...Adding /fpe:0 and it runs... Thanks for the command line options and I'd like to confirm that you have Access Violations in Release Configuration only. I think your workaround is very interesting and why did you decide to use 0?
/fpe:0 changes the choice of instructions used. 3 is the default and the only other choice is 1, which hardly anyone bothers with. (2 was suppported with DEC compilers.) It does seem that most anything that changes the instruction stream makes the problem "go away" based on what Linda has said to date.
Bernard
So Linda do you have av exception in debug or in release mode?
lklawrie
only in release mode, only with the particular compiler settings shown.
Bernard
Strange because rigorous stack checking is relaxed in release mode.Have you tried to step-in through the code?
SergeyKostrov
>>... Adding /fpe:0 and it runs... Steve, I see the following in Fortran compiler help: ... /fp: name enable floating point model variation except[-] - enable/disable floating point semantics fast[=1|2] - enables more aggressive floating point optimizations precise - allows value-safe optimizations source - enables intermediates in source precision strict - enables /fp:precise /fp:except, disables contractions and enables pragma stdc fenv_access ... and I don't see any numeric values similar to what Linda uses.
SergeyKostrov
>>... I don't see any numeric values similar to what Linda uses... Sorry, I missed it... Please ignore my previous post.
Bernard
Linda any updates related to your project?
