Hello, I am a standard user without priority support. I urgently need to download the offline installer for Intel oneAPI HPC Toolkit 2024.2 for Windows, because I’ve switched to a new PC and my legacy project depends on the classic ifort compiler, which is now obsolete. Could an administrator please provide me with a temporary direct link to w_HPCKit_p_2024.2.1 offline for Windows? Thank you.
That is not available to download unless you have priority support, Why does your program depend on IFORT, must you build 32bit?
If Intel no longer lists that installer publicly, your best option is to ask an Intel moderator or administrator directly, as they sometimes can provide temporary access to older packages if they're still available. It also helps to explain that your project specifically depends on the classic ifort compiler and that you're migrating to a new PC.
