oneapi on ubuntu 23.10
rmoortgat
I installed oneapi in Ubuntu 23.10.
The installation ran without a problem.
Oneapi is in /opt/intel/
I sourced setvars.sh.
When I open a terminal setvars.sh executes setting the environment variables.
Disaster strikes when I enter ifort --version which gives me 'Command 'ifort' not found'
I think something went wrong with the installation.
On mpiifort --version I get:
/opt/intel/oneap/mpi/2021.10.0/bin/mpiifort: 1: eval: ifort: not found.
As far as I understand ifort didn't get installed.
Roger
rmoortgat
Looks like something went wrong during installation.
I did a clean install and everything is working fine.
Roger
Barbara_P_Intel
I wonder if the new directory layout is the problem.
For detailed information about the Unified layout, including how to initialize the environment and advantages with the Unified layout, refer to Use the setvars and oneapi-vars Scripts with Linux and Use the setvars and oneapi-vars Scripts with Windows.
Ron_Green
From that terminal, after you manually enter this source command
source /opt/intel/oneapi/setvars.sh
Can you show the output of the following:
echo $0
which ifort
echo $PATH
rmoortgat
Roger
Barbara_P_Intel
Thanks for letting us know!
