open files
p_ackerer
I had some troubles with file opening (see below).
Can you tell me why options 2 & 3 are not working ?
Have a nice day,
Philippe
implicit none
INTEGER :: i,n,ind,opt
character (LEN=15) :: fichier,fich
fichier='test_o'
n=75000
write(*,*) ' Select option:'
read(*,*) opt
do i=1,N
write(*,*) ' Start',i,n
if(opt==1) open(15,file='test_o.dat',status='old') ! ok
if(opt==2) open(15,file=TRIM(fichier)//'.dat',status='old') ! program ends at i= 63913
if(opt==3) then ! program ends at i= 63913
ind=index(fichier,' ')-1
open(15, FILE=fichier(1:ind)//'.dat',status='old')
endif
if(opt==4) then ! ok
fich=TRIM(fichier)//'.dat'
open(15,file=fich,status='old')
endif
close(15)
write(*,*) ' end do'
enddo
stop
END PROGRAM test_o
tropfen
Hello Philippe,
with option 2 & 3 you using the open command to construct the file name. For this the stack is used and every time a bit more. It ends with an not shown stack overflow. This bug is old. (http://redfort-software.intel.com/en-us/forums/showthread.php?t=42116&o=a&s=lr).
To solve the problem you have to construct the file name in advance:
character(len=400) :: filename
filename=''
filename=TRIM(fichier)//'.dat'
open(15,file=filename,status='old')
This problem should be solved with IVF 12 Update 2 (see http://redfort-software.intel.com/en-us/forums/showthread.php?t=77857)
Frank
p_ackerer
Thanks Frank for your answer.
What had troubled me is that no debug option is able to detect the problem...
Philippe
