openmp in fortran
elquin
do block=1, nblock
   m = ...(block) ; n = ...(block)
   bet(m) = c(m,m)
   rhs(m) = rhs(m)/bet(m,m)
!$omp parallel do private(i)
do i=m+1, n
   gam(i) = c(i-1,i)/bet(i-1)
   bet(i) = c(i,i)-c(i,i-1)*gam(i)
   rhs(i) = (rhs(i)-rhs(i-1))*c(i,i-1)/bet(i)
end do
!$omp end parallel do
end do
I'm engineer and building the code and try to use openmp for speeding up.
The 'c' is huge matrix and gam, bet and rhs's are 1-d array.
However, when I run the above code, the result 'rhs' gives sometimes correct one but sometimes weired result also with NaN.
tropfen
Hello elquin, the problem with your code lies in the dependency of gam(i) on bet(i-1). Within an omp parallel construct no one can say at which time which part of the i loop will be calculated. For instance the loop will be separated into 4 parts durring to prozess. A simple idea is i=1,100 part 1 i=1,25; part i=26,50 and so on. Each part will be calculeted parallel. In your exemple gam(26) will be calculated before bet(25) has been calculeted. Have a look at the documentatio of openmp. Please do not use dependency in side a omp parallel loop. Frank
TimP
In addition to the race condition which Frank pointed out, you have a similar race where the calculation of rhs(i) depends on rhs(i-1). Not only do you run into the situation which Frank explained, where you sometimes use a value which has not yet been calculated; you hit the situation where one thread is writing a cache line which another thread needs to read, and you kill the performance which you are trying to achieve.
jimdempseyatthecove
I will sketch the code you might find useful !$omp parallel private(iThread, iBegin, iEnd, i) ! n threads running here iThread = omp_get_thread_num() iSliceSize = n-m ! n - (m+1) +1 iBegin = (m+1) + (iThread * iSliceSize) if(iThread .eq. (omp_get_num_threads()-1)) then iEnd = n else iEnd = iBegin + iSliceSize - 1 endif betim1 = bet(iBegin-1) !$omp barrier !$omp do do i=iBegin, iEnd gam(i) = c(i-1,i)/betim1 bet(i) = c(i,i)-c(i,i-1)*gam(i) rhs(i) = (rhs(i)-rhs(i-1))*c(i,i-1)/bet(i) betim1 = bet(i) end do !$omp end do !$omp end parallel Jim Dempsey
