29285 Discussions
openmp under ifx does not scale (at all) with number of threads, works fine with ifort
dmpogo
I have computational code, which for testing purposes just calls a subroutine with 3 nested loops
!$OMP PARALLEL DO DEFAULT(FIRSTPRIVATE) &
!$OMP             SHARED(prm,spec_x,spec_y,spec_z,speq_x,speq_y,speq_z)
     do j3=1,n3.
        do j2=1,n2
           do j1=1,nyq1_1
            endtime OMP_NUM_THREADS=1 ./mag_field < input_text
do
         enddo
     enddo
!$OMP END PARALLEL DO
where innermost loop has some calls to MKL routines
I have 3 platforms -   2011 desktop with intel i7 Core   4cores/8 threads  and ifort 2021.2,   2017 laptop with intel i7 Core and  ifx 2025.0.4  2 cores/4 threads  and Supermicro server with Intel Xeon  48 cores/96 threads 2025.1.1
The code is compiles with FFLAGS= -w -extend_source -O -qopenmp
Here are the strange results
ifort platform
$   time OMP_NUM_THREADS=1 ./mag_field < input_text
real    4m45.787s
user    4m45.206s
sys     0m0.567s
$  time OMP_NUM_THREADS=4 ./mag_field < input_text
real    1m15.504s
user    4m36.408s
sys     0m0.700s
As expected,   the user time remain the same, while the wall time decreased by almost factor of 4
But same code and compiler options on  ifx platforms give
laptop
real    1m9.073s
user    1m8.716s
sys     0m0.284s
real    0m35.847s
user    2m19.619s
sys     0m0.428s
user time went up by a factor of 2 and real time improvement is only twice, not 4 times. This platform, however, has only 2 real cores.
But even more dramatic is the result on the server  with ifx compiler
real    0m44.983s
user    0m44.457s
sys     0m0.517s
real    0m37.040s
user    2m24.184s
sys     0m1.092s
There is no improvement in real time at all,  but instead the user times increased almost 4 times.
I could see 4 CPU's working at 100%,  but it looks like they spent as much time as a single CPU did.
I am probably missing something important how to use OpenMP with ifx
