optimizer question
Brian_Murphy
New Contributor II
I have a program for which a Debug build runs ok, but a Release build doesn't (it runs, but results are wrong).  So I changed Release Optimization from /O2 to /Od and then it runs ok.  Is this an indication that the program has a bug somewhere?
A weird part about this is that the /O2 code fails to run correctly on one win7 system, but runs successfully on another win7 system.  The program is built statically and its only dependencies are KERNEL32.DLL and IMAGEHLP.DLL
jimdempseyatthecove
I see an issue.
In the optimized code, the optimization chose to produce the reciprocal of a register as opposed to performing a divide.
IMHO the produced reciprocal is abizmally off.
0032103F 0F 53 DA             rcpps       xmm3,xmm2
where:
XMM20 = +2.00000E+000      XMM21 = +2.00000E+000      XMM22 = +0.00000E+000      XMM23 = +0.00000E+000      XMM30 = +4.99878E-001      XMM31 = +4.99878E-001      XMM32 = +1.#INF0E+000      XMM33 = +1.#INF0E+000
IOW the reciprocal of 2.0 became 0.499878
Add /fp:precise to the affected code
    2.0000000000E+00    2.0000000000E+00    1.0000000000E+00    1.0000000000E+00
            40000000            40000000            3F800000            3F800000
Steve, is there an option other than /fp:precise (which is broad in nature) that instructs to not perform a fast reciprocal?
Also, in this case, the accuracy of the approximate fast reciprocal is less than desirable.
Jim Dempsey
jimdempseyatthecove
BTW: rdpps: Compute the approximate reciprocal of packed single-precision (32-bit) floating-point elements in a, and store the results in dst. The maximum relative error for this approximation is less than 1.5*2^-12.
1.5 / 4096 = 0.0003662109375 (~ 3.3 decimal places)
Jim Dempsey
mecej4
Jim has found the problem! If the processor has an instruction to compute a reciprocal to the same precision as multiply and divide instructions, using that (instead of a divide instruction) as a means of optimization would be fine. RCPPS does not meet this criterion. A low-accuracy approximation such as that generated by RCPPS is appropriate for use as a starting value in an iterative process. I feel that its use in the example code is inappropriate, and should be considered an optimizer bug.
Please discuss or state opposing opinions.
P.S., added on 16 March 2020:
Examination of the assembly code and running in the debugger shows that, in fact, after the initial approximation x0 to 1/N is produced using RCPPS, and one step of Newton-Raphson  is applied to obtain an improved approximation x1. For N = 2.0, x0 = 0.49975589, and x1 = 0.49999997 (Z'3EFFFFFF'), which is off in the LSB.
I see now that my claim that integer powers of 2 are represented exactly in the FPU  has been proven wrong. I had not been aware that the compiler generated reduced precision instructions such as RCPPS. A compiler option to avoid the use of RCPPS and its ilk would be helpful to users. With Gfortran, for instance, I observed the same behavior as above but after I used the options -O3 -funsafe-math-optimizations -ffinite-math-only -fno-trapping-math .
JohnNichols
Valued Contributor III
Performs a SIMD computation of the approximate reciprocals of the four packed single-precision floating-point values in the source operand (second operand) stores the packed single-precision floating-point results in the destination operand. The source operand can be an XMM register or a 128-bit memory location. The destination operand is an XMM register. See Figure 10-5 in the Intel® 64 and IA-32 Architectures Software Developer’s Manual, Volume 1, for an illustration of a SIMD single-precision floating-point operation.
The relative error for this approximation is:
|Relative Error| ≤ 1.5 ∗ 2−12
https://www.felixcloutier.com/x86/rcpps
Performing a reciprocal is always dangerous.
jimdempseyatthecove
Steve, I cannot locate a switch in the IVF V19.1 to specify to the compiler to use reciprocals together with one iteration of Newton-Raphson as outlined in the 64-ia-32-architectures-optimization-manual...pdf
Accuracy  Method                 SSE Performance        AVX Performance
 24 bits (V)DIVPS                Baseline               1X
~22 bits (V)RCPPS+Newton-Raphson 2.7X                   4.5X
~11 bits (V)RCPPS                6X                     8X
Is there such an option?
Jim Dempsey
Steve_Lionel
Sorry, I don't know. Please raise this to Intel Support.
JohnNichols
Jim Dempsey
this is like the old days - back with the 80286 processor -- you  had limited memory and often had to choose how to make routines faster -- interesting trading the speed for accuracy numbers, I would have thought Newton Raphson would have caused a bigger hit -- it is quite a complex routine.
Got to love the modern era - now we have real viruses that Norton cannot kill
mecej4
The compiler would certainly not generate a call to a general purpose Newton-Raphson routine, external or inline.
The one-iteration Newton-Raphson calculation for calculating 1/A, given A, is
Use RCPPS to find x_0, a 12 bit approximation to x = 1/A.
Calculate x_1 = (2 - A.x_0) x_0, which gives the 22 bit approximation x_1.
jimdempseyatthecove
Yes, however, the compiler could generate the additional instructions in line.
Out of curiosity, I looked at Agner Fog's instruction set timings and I to not see how vrcpps + vmulps can beat vdivps. (at least not 8x).
Jim Dempsey
Barbara_P_Intel
Can you check -fltconsistency and -prec-div in the Developer Guide?
