optional parameter error
qiu_n_
My dear friend:
my new version compiler is ifort version 19.0.2.187
system is linux(redhat)
my compiler is following:
ifort -c head_sublibf.f90 -std03 -fPIC -assume nounderscore -assume bscc -assume byterecl -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -fpp
my code Complier and link is ok ,but run my code ,when it call the subroutinue is core .
If optional no default, i have it trc = 1 and channel = 0, my code runing is ok!
please help me ,thank!
following is part code :
!   my module:head_sublibf.f90      hdd_get is polymorphism  interface
   MODULE head_sublibf
    interface
    integer( c_int ) function hdd_seti_by_name(name,head_buffer,result,trc,channel )  bind( C )
    use, intrinsic::ISO_C_BINDING
    implicit none
    character (len = *) ::name
    integer(C_INT), dimension(*)::head_buffer
    integer (C_INT):: result
    integer (C_INT),OPTIONAL:: trc
    integer (C_INT),OPTIONAL:: channel
    end function hdd_seti_by_name
   end interface
    INTERFACE hdd_get
      MODULE PROCEDURE fhddgeti_byname
      MODULE PROCEDURE fhddgetl_byname
      MODULE PROCEDURE fhddgetf_byname
      MODULE PROCEDURE fhddgetd_byname
    END INTERFACE
      integer(C_INT) FUNCTION fhddgeti_byname( name,head_buffer,result,trc,channel )
      use,intrinsic::ISO_C_BINDING
      implicit none
        integer (C_INT)::trc_default
        integer (C_INT)::channel_default
        write(*,*) "--------- fhddgeti :",name
        write(*,*) "trc:",trc
        write(*,*) "channel: ",channel
        if(present(trc) ) then
           trc_default =trc
        else
!           write(*,*) " default parameter --- trc"
           trc_default =1
        endif
        if(present(channel)) then
           channel_default =channel
        else
!           write(*,*) " default parameter --- channel"
           channel_default =0
        endif
!        write(*,*) "--------- fhddgeti - name :",no
!        write(*,*) "--------- fhddgeti - trc:",trc_default
!        write(*,*) "--------- fhddgeti - channel:",channel_default
        fhddgeti_byname = hdd_geti_by_name(name,head_buffer,result,trc_default,channel_default)
      END FUNCTION
    END MODULE
following is program.  it call module (head_sublibf.f90)
 1         dytest1 = hdd_get("max_samples",head,iresult,1,0)
 2         write(*,*) "AM---name parameter samples-------n :",dytest1, iresult
 3         dytest = hdd_get("max_samples",head,iresult)
 4         write(*,*) "AM---name parameter samples --- name:",dytest, iresult
code Line Numbers 1  optional parameter is 1,0 .i give it .the subroutine call is right. Line Numbers 2 give right resulte.
code Line Numbers 3  the optional parameter i use default value. (default is 1,0). the subroutine call is core.
i don't know why?
please tell me 。 where is wrong ? thanks!
mecej4
Please present working program source that can be compiled and run. What you showed above is quite incomplete and the parts shown are fragmented.
qiu_n_
My job code, call a lot of other people's code, without that code can't run, I can only give such logic code。
I suspect that string in the module and interface, cause the failure of the program runs。
But I'm not sure, i do not know how to define is right.
jimdempseyatthecove
Does: fhddgeti_byname = hdd_geti_by_name(name,head_buffer,result,trc_default,channel_default)
Open an I/O unit associated with the value of channel_default and/or trc_default?
If so, then if  hdd_geti_by_name also leaves the I/O unit open, then the second call using the same values for channel_default and/or trc_default will error on I/O unit in use.
Jim Dempsey
qiu_n_
hdd_geti_by_name is c subroutine.  channel_default and/or trc_default is optional parameter in hdd_geti_by_name.
jimdempseyatthecove
While hdd_geti_by_name is a C routine, it may still obtain a resource based on channel_default and/or trc_default. Ergo the question remains unanswered: Does the first call to hdd_geti_by_name (with the same values for channel_default and/or trc_default) cause a conflict (i.e. in use) when called the second time with the same values?
Jim Dempsey
