order of derived type definitions
raov
The code below compiles with ifort8, Lahey/Fujitsu, and Absoft,but not ifort9,
the latter saying
str_type_bug.f90(5) : Error: This name does not have a type, and must have an explicit type. [TT]
type(ap), pointer :: tt(:)
ifort9 compiles it if the derived type ap is defined
before au or if in function foo, 'value' is declared
as in the commented-out line
I am using W_FC_P_9.0.018
module amod
implicit none
type :: au
end type au
type :: ap
real :: ss
end type ap
contains
function foo(xx) result(value)
type(au) , intent(in) :: xx
! real :: value(2)
real :: value(size(xx%tt))
value = 0.0
end function foo
end module amod
Looks like a bug. Please report it to Intel Premier Support.
Hmm - looks like a bug. With the pointer attribute, you're allowed to name a type defined later. Please report it to Intel Premier Support.
This is an odd case. It is not strictly the order of declaration, as if you use the declaration value(2) in the subroutine instead of value(size(xx%tt)), it works. But you're right that reordering the declarations allows both cases to compile.
I think this is a bug and I'll report it to the developers. I'd encourage you to file a report to Intel Premier Support if you want to be notified of the fix.
