29285 Discussions
viewing parameter in Debug mode (9.0.019)
tropfen
what do i have to do to view a parameter in the debug mode.
All i can see is "Undefined variable ... "
I have used a complete new sample program in IVF 9.0.019
Thanks in advance
Frank
You need to add the /debug-parameters option to the command line. If you are using the IDE, there is not yet a "property" for this, so select Command Line and add it there. The property will be added in a future update.
See the Release Notes or the on-disk documentation for more details on the use of this switch and its three optional values (none, used, all).
