output change
AHAD_K_
Hi
When I run my code the PRINT*, or WRITE(*,*) statement inside the loop
changes the result. This happens when I want to print two variable
but when I print just one variable results are different.
following is that part of the code:
COMPLEX*16 AMU, ANU , AMUNU, ANUMU, CHERN,
$ FMUNU, DIFFA
WRITE(*,*) DIFFA
WRITE(*,*) FMUNU
when I just print one of DIFFA or FMUNU the result is different from the time
of writing both of them.
Thank you
mecej4
This behavior is typically a result of a bug in your program, possibly compounded by optimization of the buggy code.
To find a solution, we need a complete example source code that exhibits this behavior.
