overload MATMUL(a,b) as a*b
nooj
This has got to be in the FAQ, but I didn't see it in any forum search or the googles.
I'd like to use the notation "C = A*B" to mean "C = MATMUL(A,B)". If I write a simple operator interface,
[bash]interface operator(*)
  intrinsic matmul
end interface operator [/bash]
I get "This statement is incorrectly positioned" because I don't know what I'm doing. If I write a more complicated interface that actually works, I lose much of the beauty and versatility of the builtin MATMUL interface. Reading reference manual entries for the "interface" statement left me confused.
Is there a good way to say simply "A*B" means "MATMUL(A,B)" (without knowing the size or type of A or B, for instance)? I'd also like "A*B*C" to mean "MATMUL(MATMUL(A,B),C)" as one might expect.
Overloading DOTPRPDUCT in a similar fashion (perhaps not using the same symbol) would also be nice.
- Nooj
david_car
Nooj,
To be able to override operators you need to be define a derived type that you can override the * operator on. Heres an example:
[bash]module class_Matrix
  type Matrix
    real :: data(10, 10) = 1.
  end type Matrix
    module procedure multMatrix
  end interface
contains
  function multMatrix( this, other ) result( res )
    type (Matrix), intent(in) :: this, other
    type (Matrix) :: res
    res % data = MATMUL( this % data, other % data )
  end function multMatrx
end module class_Matrix
program main use class_Matrix type (Matrix) :: a, b, c c = a * b end program [/bash]
This is a very simple version to get you thinking and started. The Matrix class stores only a 10x10. So you really need to make this allocatable data and provided a constructor to create a matrix type. This can all be placed in a module and you have yourself a nice matrix type. You may also want to look at reference counting your objects, but I won't get into any details here. You can check my project page below and download it to see examples of things like that. Have fun.
david_car
Nooj,
  type Matrix
  end type Matrix
  end interface
contains
david_car
Sorry. The code syntaxhighlighter did some mangling to the code above. Not sure why.
The problem with the syntaxhighlighter has been reported.
nooj
David -
> To be able to override operators you need to define a derived type that you can override the * operator on.
Thanks so much! This was the key I was looking for, and explains why I kept seeing examples like the one you gave.
I'll take a look at your modules and see if they work for me. I've found that for new code, I'm interested in readability and ease of use; but after things mature and become bulletproofed, I adjust them for speed. So I would like to be able to use compatible data structures for both.
- Nooj
joseph-krahn
My preference would be to use named operators, such as ".matmul." and ".dot.", rather than replace the scalar multipl ication operator.
David's example uses a matrix class object, rather than directly using Fortran matrices. A matrix class can provide more features, but makes your code specific to that specific class implementation.
&nb sp;
If you want to operate on standard Fortran matrices, you will need to provide wrapper procedures for each al lowed combination of arguments. Here is an example for the three forms of REAL(4) calls. The intrinsic MATMUL handles al l combinations of numeric types, as well as logical types. To support all valid combinations of 4 and 8 byte logical, in teger, real, and complex types, you will need 2*2+6*6=40 sets of three procedures shown here. (Logical and numeric types don't mix.) So, it is not hard to support one or two types, but is excessive to make a completely general interface.
The source-code formatter seems to be randomly chopping lines, so I will include this as an attachment as well.
[fortran]module matmul_op
  interface operator(.matmul.)
    module procedure matmul22_r4
    module procedure matmul12_r4
    module procedure matmul21_r4
  end interface operator(.matmul.)
contains
  pure &
  function matmul22_r4(m1,m2) result(prod)
    real(4), intent(in) :: m1(:,:), m2(:,:)
    real(4) :: prod(size(m1,1),size(m2,2))
    prod = matmul(m1,m2)
  end function matmul22_r4
  pure &
  function matmul21_r4(m1,m2) result(prod)
    real(4), intent(in) :: m1(:,:), m2(:)
    real(4) :: prod(size(m1,1))
  end function matmul21_r4
  pure &
  function matmul12_r4(m1,m2) result(prod)
    real(4), intent(in) :: m1(:), m2(:,:)
    real(4) :: prod(size(m2,2))
  end function matmul12_r4
end module matmul_op
program matmul_test
  use matmul_op
  real(4) :: v1(3) = (/ 2,3,4 /)
  real(4) :: m1(2,3) = reshape((/ 2,3,4, 3,4,5 /),(/2,3/))
  real(4) :: m2(3,2) = reshape((/ 2,3, 3,4, 4,5 /),(/3,2/))
  write(*,*) m1.matmul.m2
  write(*,*) matmul(m1,m2)
  write(*,*)
  write(*,*) v1.matmul.m2
  write(*,*) matmul(v1,m2)
  write(*,*)
  write(*,*) m1.matmul.v1
  write(*,*) matmul(m1,v1)
  write(*,*)
  write(*,*) m1*transpose(m2) ! just to show that * is still usable
end program matmul_test
[/fortran]
david_car
Hey Joe. I'm glad you brought this up. The PyF95++ link below is to my Fortran templating open source project. If you use it, you only have to maintain just one code base. It mimics the templating you'll find in C++ and also comes with the a template library with lists, queues, stacks, hashtable/dictionary, etc... I welcome input and contributions. With it, a templated version of the original Matrix class I posted would look like:
[bash]template
module class_Matrix
AutoUse end AutoUse
implicit none
AutoPrivate end AutoPrivate
type Matrix
__OBJECT__ :: data(__ROW__, __COL__) = 1.
end type Matrix
AutoInterface
end AutoInterface
contains
function multMatrix( this, other ) result( res ) as operator(*)
type (Matrix<__OBJECT__, __ROW__, __COL__>), intent(in) :: this, other
type (Matrix<__OBJECT__,__ROW__,__COL__>) :: res
res = MATMUL( this, other )
end function multMatri
end template
program main
AutoUse
end AutoUse
type (Matrix) :: ia, ib, ic
ic = a * b
ic = ia * ib
end program [/bash]
Now you can just stamp out any type of matrix you would like with only one code base. There is an upcoming ACM Fortran Forum article with more details. The "Auto*" blocks take care of generating the interfaces and importing the correct modules. All the best.
david_car
Obviously the syntaxhighlighter is not properly display the less than < and greater than > symbols. Sorry about that. Just click "view plain" and you should see it properly.
I've reported the angle bracket problem. This is apparently a side-effect of a recent fix for the spurious blanks,
