when running the following code I noticed that the memory locations differ when using the overloaded assignment or the bound procedure directly, where the bound procedure is behaving as expected. it implies that when using the operator a temporary copy of the rhs is made, although compiling with -check arg_tmp_created did not report anything. the results can be produced with ifort 19.04, 19.05, 19.1.0 and 19.1.1. When the same code is compiled with gfortran both, the overloaded assignment operator and the bound procedure produce the same output.
module mod_t1
implicit none
type :: t1
integer, allocatable :: i1(:)
contains
generic, public :: assignment(=) => cpi1
procedure, public :: cpi1 => subcpi1
end type t1
contains
subroutine subcpi1(this,i1i)
class(t1), intent(inout) :: this
integer, intent(in) :: i1i(:)
write(*,*) loc(i1i(1)), loc(i1i(size(i1i)))
if(allocated(this%i1)) deallocate(this%i1)
allocate(this%i1,source=i1i)
end subroutine subcpi1
end module mod_t1
program test
use mod_t1
implicit none
integer, allocatable :: a(:)
class(t1), allocatable :: t
allocate(t);a=(/1,2,3/)
write(*,*) loc(a(1)), loc(a(size(a)))
call t%cpi1(a)
t=a
end program test
the output from ifort is:
35083136 35083144
35083136 35083144
140725714160336 140725714160344
from gfortran:
94244671338848 94244671338856 94244671338848 94244671338856 94244671338848 94244671338856
if the compiler invokes a temporary copy it may cause difficult to trace performance issues when using the operator. I suspect a bug in ifort but seek confirmation before I report to intel.
cheers
The standard doesn't discuss implementation details such as whether temporaries in memory are created or not - it specifies how statements will operate using Fortran concepts such as the execution sequence for statements or how the value of variables will change.
The standard specifies that the right hand side of an defined assignment statement is treated as if it was a parenthesised expression prior to the actual and dummy arguments being associated (F2018 15.4.3.4.3). This is to avoid aliasing issues that would otherwise apply for a direct procedure call without parentheses, if the left and right hand sides of the assignment statement involved a common object in some way. One way of implementing the handling of a parenthesised expression is to create a temporary. Doing this regardless of whether there is the potential for a common object on the left and right hand sides of the assignment is not particularly efficient, but it does the job.
I have open bug reports (59202) with gfortran due to a failure to correctly handle left and right hand side parts of an assignment statement that are aliased. Not creating a temporary in those cases is efficient from an execution point of view, but broken.
What means a common object?
If I expand the code to
module mod_t1
implicit none
type :: t1
contains
generic, public :: assignment(=) => cpi1,cpi2
procedure, public :: cpi2 => subcpi2
end type t1
contains
subroutine subcpi2(this,ot)
class(t1), intent(in) :: ot
write(*,*) loc(ot), loc(ot)
allocate(this%i1,source=ot%i1)
end subroutine subcpi2
end module mod_t1
program test
use mod_t1
implicit none
class(t1), allocatable :: x,y
allocate(x,y);a=(/1,2,3/)
call x%cpi1(a)
x=a
write(*,*) loc(x), loc(x)
call y%cpi2(x)
y=x
end program test
I get
9892864 9892872
9892864 9892872
140732849527360 140732849527368
9892608 9892608
9892608 9892608
9892608 9892608
which suggest when the operator is used between objects of the same class no temporary copy is made.
is this still consistent with what you wrote above?
By common object I mean something (or part of something) that appears on both the left and right hand sides of the assignment statement.
Behaviour in the second example is consistent - if a temporary is not required to implement the semantics required by the standard, there's no requirement to create a temporary. But the example is not sufficient to test the compiler is doing the right thing.
It is possible for a compiler (and this is the sort of thing I would expect ifort to do) to analyse the semantics in the code invoking the defined assignment and determine that there is no possibility of aliasing between x and y (x and y are both allocatable local variables). If there is no possibility of aliasing, then a temporary is not required.
But ifort is not doing that analysis (or is not doing it correctly) - it is not defending against aliasing in circumstances where it needs to - the behaviour in the following, where there is aliasing, demonstrates a compiler bug for the polymorphic case (note the repeated 3 in the output). In the non-polymorphic case the compiler has identified that the left and right are aliased, and has appropriately created a temporary.
module mod_t1
implicit none
type :: t1
integer :: i1(3)
contains
generic, public :: assignment(=) => cpi2
end type t1
contains
integer :: i
write(*,"(*(Z16.16,:,1X))") loc(ot%i1)
! Flip the order - if the arguments are aliased this may
! demonstrate an issue.
do i = 1, size(this%i1)
this%i1(i) = ot%i1(size(ot%i1)-i+1)
end do
end module mod_t1
program test
use mod_t1
implicit none
type(t1), allocatable :: y
allocate(x, y)
x%i1 = [1, 2, 3]
write(*,"(*(Z16.16,:,1X))") loc(x%i1)
x=x ! x=(x) gives an ICE
print *, x%i1
y%i1 = [1, 2, 3]
write(*,"(*(Z16.16,:,1X))") loc(y%i1)
y=y
print *, y%i1
end program test
>ifort /Od /warn:all /check:all /traceback "2020-04-15 defined-assignment-2.f90" && "2020-04-15 defined-assignment-2.exe"
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.1.1.216 Build 20200306
Copyright (C) 1985-2020 Intel Corporation. All rights reserved.
Microsoft (R) Incremental Linker Version 14.25.28612.0
Copyright (C) Microsoft Corporation. All rights reserved.
"-out:2020-04-15 defined-assignment-2.exe"
-subsystem:console
-incremental:no
"2020-04-15 defined-assignment-2.obj"
0000018DC2FA3930
0000018DC2FA3930
3 2 3
0000018DC2FA3960
00000009AE3DF680
3 2 1
