In a previous thread I asked for help because of a circular depenendy. I solved it by using submodules. Now I want to have a type bound overloaded subroutine in a submodul.
Current status which is working fine
PROJECT.f90
MODULE mProject IMPLICIT NONE PRIVATE PUBLIC :: tElement TYPE tElement CONTAINS PROCEDURE, PUBLIC :: other_subroutine => other_subroutine_element END TYPE tElement INTERFACE MODULE SUBROUTINE other_subroutine_element(this) IMPLICIT NONE CLASS(tElement), INTENT(INOUT) :: this END SUBROUTINE other_subroutine_element END INTERFACE END MODULE mProject
ELMENT.f90
SUBMODULE (mProject) mElements IMPLICIT NONE CONTAINS MODULE SUBROUTINE other_subroutine_element(this) IMPLICIT NONE CLASS(tElement), INTENT(INOUT) :: this ! doing smth here END SUBROUTINE other_subroutine_element END SUBMODULE
Now I want to add to tElement a overloaded type bound subroutine. How do i do that
MODULE mProject IMPLICIT NONE PRIVATE PUBLIC :: tElement TYPE tElement CONTAINS PROCEDURE, PUBLIC :: overloaded_subroutine => overloaded_subroutine_element PROCEDURE, PUBLIC :: other_subroutine => other_subroutine_element END TYPE tElement INTERFACE overloaded_subroutine_element MODULE PROCEDURE overloaded_sub1 MODULE PROCEDURE overloaded_sub2 END INTERFACE overloaded_subroutine_element INTERFACE MODULE SUBROUTINE other_subroutine_element(this) IMPLICIT NONE CLASS(tElement), INTENT(INOUT) :: this END SUBROUTINE other_subroutine_element MODULE SUBROUTINE overloaded_sub1(this, int) IMPLICIT NONE CLASS(tElement), INTENT(INOUT) :: this INTEGER(4), INTENT(IN) :: int END SUBROUTINE overloaded_sub1 MODULE SUBROUTINE overloaded_sub2(this, real) IMPLICIT NONE CLASS(tElement), INTENT(INOUT) :: this REAL(8), INTENT(IN) :: real END SUBROUTINE overloaded_sub2 END INTERFACE END MODULE mProject
and for ELEMENT.f90
SUBMODULE (mProject) mElements IMPLICIT NONE CONTAINS MODULE SUBROUTINE other_subroutine_element(this) IMPLICIT NONE CLASS(tElement), INTENT(INOUT) :: this ! doing smth here END SUBROUTINE other_subroutine_element MODULE SUBROUTINE overloaded_sub1(this, int) IMPLICIT NONE CLASS(tElement), INTENT(INOUT) :: this INTEGER(4), INTENT(IN) :: int ! doing smth here END SUBROUTINE overloaded_sub1 MODULE SUBROUTINE overloaded_sub2(this, real) IMPLICIT NONE CLASS(tElement), INTENT(INOUT) :: this REAL(8), INTENT(IN) :: real ! doing smth here END SUBROUTINE overloaded_sub2 END SUBMODULE
unfortunately this is not how its working.
PROJECT.f90(9): error #8182: The name is neither an abstract interface nor a procedure with an explicit interface. [OVERLOADED_SUBROUTINE_ELEMENT]
PROJECT.f90(9): error #8258: The procedure name in a type-bound procedure declaration should be the name of an accessible module procedure or an external procedure that has an explicit interface. [OVERLOADED_SUBROUTINE_ELEMENT]
Someone has any thoughts on this?
Julian wrote:
.. Now I want to add to tElement a overloaded type bound subroutine. How do i do that ..
Add a GENERIC binding to your type, as shown below:
module mProject
implicit none
private
public :: tElement
type tElement
contains
private ! <-- Look into this, consider making this the default
procedure, pass(this) :: overloaded_sub1 !<-- suggestion: explicitly declare the PASS attribute
procedure, pass(this) :: overloaded_sub2
procedure, pass(this), public :: other_subroutine => other_subroutine_element
generic, public :: overloaded_subroutine_element => overloaded_sub1, overloaded_sub2 !<-- overloading
end type tElement
interface
module subroutine other_subroutine_element(this)
implicit none
class(tElement), intent(inout) :: this
end subroutine other_subroutine_element
module subroutine overloaded_sub1(this, int)
implicit none
integer(4), intent(in) :: int
end subroutine overloaded_sub1
module subroutine overloaded_sub2(this, real)
implicit none
real(8), intent(in) :: real
end subroutine overloaded_sub2
end interface
end module mProject
Also look in the references for more such details:
https://software.intel.com/en-us/blogs/2013/12/30/doctor-fortran-in-its-a-modern-fortran-world
thanks a lot
