29413 Discussions
overriding procedure -- extended type arguments
elwong
I'm trying to write a subroutine for an extended type to copy data from one object to another.
However, it seems that what I'm trying to do isn't legal:
>> gfortran -c test1.f90
test1.f90:23.14:
procedure :: copy => t1copy
1
Error: Types mismatch for dummy argument 'b' of 'copy' (1) in respect to the overridden procedure
I guess the second argument 'b' must be exactly the same type, in this case class(t0) and not t1, the extension. Does anyone have suggestions on what I could do instead?
[fortran]module t0mod
  type :: t0
     integer :: i
   contains
     procedure :: copy => t0copy
  end type t0
contains
  subroutine t0copy ( a, b )
    class(t0) :: a, b
    b%i = a%i
  end subroutine t0copy
end module t0mod
module t1mod
  use t0mod
  type, extends(t0) :: t1
     integer :: j
   contains
  end type t1
contains
  subroutine t1copy ( a, b )
    class(t1) :: a, b
    b%j = a%j
  end subroutine t1copy
end module t1mod
[/fortran]
elwong
I should add I get the same error from ifort, which leads me to believe what I have is not legal.
Hirchert__Kurt_W
New Contributor II
The typical solution involves the use of the SELECT TYPE construct. Here's one possible solution:
class(t1) :: a
class(t0) :: b
select type(b)
class is (t1)
b%j = a%j
class default
call a%t0%copy(b)
end select type
end subroutine
If you don't want to revert to the class(t0) copy when b is not class(t1), you could generate some kind of error message in the CLASS DEFAULT block instead.
I note that, as written, your class(t0) copy copies the i component, and your class(t1) copy copies the j component, but not the i component. This seems an atypical choice. If you wanted your class(t1) copy to also copy the class(t0) components, you need to make that explicit. For that, the body of t1copy might look more like
call a%t0%copy(b) ! copy the base components
select type(b) ! if b also is class(t1), copy the t1 components
class is (t1)
b%j = a%j
end select type
In this version, I left out the CLASS DEFAULT because it wasn't going to do anything, and that's what happens if it is omitted.
Does any of this help?
-Kurt
elwong
Thanks for that nice solution. I was ready to try to overload the = operator, but this is much better.
As for not copying the i component in class(t1)...I just wrote the example quickly and neglected to copy i. The real code was too complicated to post here, but there I do call the parent's copy subroutine.
