parallel calculation using a DLL
LRaim
I have searched, with no success, an example of parallel computation  where a called fundamental function is implemented in a DLL.
I.e. the basic structure to be parallelized is:
DO I=1,N,1
CALL SUB1(ZPARM1(I),ZPARM2(I), ..., OUTVAL1(I))
ENDDO
with SUB1 implemented as a DLL.
Does anybody knows some example ?
There's nothing special about a DLL here - conceptually it's no different than calling a procedure linked in directly. The same issues apply regarding parallelism in making sure you build thread-safe code.
jimdempseyatthecove
In case you may have misunderstood Steve's response. Your DLL must also be thread-safe. You can compile it with -openmp even though it may not directly have any OpenMP statements. Alternatively you can add the -recursive and/or reentrant options.
Jim Dempsey
