29640 Discussions
parallel lint for ifort omp* checking
mirko_vukovic
The ifort documentation (for linux) mentions the use of `parallel lint' to verify OpenMP code.
Is parallel lint an intel product (or part of one)? I could not find anything on the web site.
Mirko
pbkenned1
The parallel lint you're referring to is part of the compiler. It performs a static global analysis of your OpenMP program. Compiling with -openmp -diag-enable sc-parallel3 will produce verbose diagnostics.
Patrick Kennedy
Intel Developer Support
mirko_vukovic
ah! (or duh!)
thank you,
Mirko
mirko_vukovic
Well, I spoke too soon (maybe time for another `duh').
I tried the ifort -openmp -diag-enable sc-parallel3 -c test.f90 command on the following code (an example from the Parallel Lint section):
[bash]parameter (N = 10)
integer i
integer, dimension(N) :: factorial
factorial(1) = 1
!$OMP PARALLEL DO
do i = 2, N
factorial(i) = i * factorial(i-1)
end do
print *, factorial
end
[/bash]
I don't get an error report. What else needs to be done?
Mirko
TimP
Interesting. If I set -parallel -par-report2 it reports "existence of parallel dependence," so the analysis capability is there somewhere.
When I run this, there's no evidence of use of a second thread, possibly because the loop is so short.
pbkenned1
This may not be documented, butlint requires interprocedural (whole program) analysis to work, and you don't get that if compiing with -c. Just remove the -c:
> ifort -openmp -diag-enable sc-parallel3 test.f90 test.f90(8): warning #12246: flow data dependence from (file:test.f90 line:8) to (file:test.f90 line:8), due to "FACTORIAL" may lead to incorrect program execution in parallel mode
Another quirk is that '-diag-enable sc-parallel3' just does lint, and no executable is produced. So remove those flags to make an executable:
> ifort -openmp test.f90 && ./a.out
1 2 6 24 120 720
0 0 0 0
Clearly the compiler was onto something, as the last four outputs are not the factorials of {7,8,9,10}. You'll get the correct answer with one thread:
> export OMP_NUM_THREADS=1
> ./a.out
1 2 6 24 120 720
5040 40320 362880 3628800
Patrick Kennedy
