I am trying to help someone run a FORTRAN 77 code on the Intel Fortran 11 compiler where they are having difficulty with a FORMAT specifier. They have told me that the followingFORMAT worked on COMPAQ Fortran,
format((g13.6, ','),(g13.6,','),(g13.6,','),(g13.6))
even when N = 1. Running this on Intel Fortran will create an error when N = 1.
I have written a "variable" format specifier for them but was wondering if there is a way of setting one of the Project properties to allow this to work?
Thank you very much for your help.
Sincerely,
David
Sincerely,
David
A copy of the CVF reference manual is available online .
The CVF 6.6 reference manual states on p.51 of the I/O Formatting chapter:
"If the value of a variable format expression does not obey the restrictions on magnitude applying to its use in the format, an error occurs",
and on p.8 of the same chapter: "r Is a repeat specification. The range of r is 1 through 2147483647 (2**31-1). If r is omitted, it is assumed to be 1."
These quotes refute what you were told regarding the use of a zero repeat factor.
Why not change your code to
format((g13.6, ','),(g13.6,','),(g13.6))
This will then work for all N>=1
David
David
Good catch David
I think the original code was a modification when the format specifier had different width.
He could also use
format((g13.6,','))
He could also use
format(
Hi David!
The person I am trying to help wants to write out a file in CSV format which would put commas in between each output variable. Your fix would only work for N > 0. He has cases of N = 0. I guess he was mistaken about the case when N = 0. As I said in my original post, I sent him a modified version that will create a variable format by constructing a format string, fmt,that is used as,
format(fid, fmt) x, y, ...
Thanks for your input!
David
David
It's possible that CVF did something which worked in this context, even though the action for N==0 wasn't defined. Of course, this never was Fortran 77, even within the limits where CVF defined it. Dependence on implementation dependent behavior of 0 length constructs was more common prior to F77; F77 compilers often had switches to support some of it.
Here is a test with CVF 6.6.
[fxfortran] program refute
integer N
real X(2)
X(1)=10.0
X(2)=20.0
N=3
write(*,10)X
N=2
WRITE(*,10)x(2)
N=1
WRITE(*,10)x(2)
10 format((g13.6,','))
end
[/fxfortran] The output:[bash] 10.0000 , 20.0000 , 20.0000 , forrtl: severe (68): variable format expression value error, unit -1, file CONOUT$ Image PC Routine Line Source ref.exe 00405749 Unknown Unknown Unknown ref.exe 004055A7 Unknown Unknown Unknown ref.exe 00404784 Unknown Unknown Unknown ref.exe 00404BB9 Unknown Unknown Unknown ref.exe 00403A77 Unknown Unknown Unknown ref.exe 00402AC3 Unknown Unknown Unknown ref.exe 00401122 REFUTE 11 ref.f ref.exe 00427399 Unknown Unknown Unknown ref.exe 0041E684 Unknown Unknown Unknown kernel32.dll 7C817077 Unknown Unknown Unknown[/bash]
One more format unto the breach...
If "someone" was happy using an extension to F77 previously, then I could suggest another F77 extension that is pretty common in fortran compilers these days (the extension being part of F90...).
And you can get rid of that pesky N thing.
[fortran]program format_me implicit none real :: x(5) = [1.0,2.0,3.0,4.0,5.0] write (*, 100) x(1:0) write (*, 100) x(1:1) write (*, 100) x(1:2) write (*, 100) x(1:5) 100 format(99999(G13.6,:,',')) end program format_me [/fortran]
