parallel studio cluster
sahgal__vardaan
Hi
I am using ubuntu 18.04 64 bit platform, working with intel compiler Parallel studio Xe_2019_cluster edition    ifort version 19.0.4.243
pl let me know what is the default integer size using intel compiler
1  how can i set flags to get 64 size ie i8 for mkl cluster  in bash file
2  how to find out the size (bit) of Open MPI installated
3  what is this error  and how to overcome this
Could NOT find OpenMP_Fortran (missing: OpenMP_Fortran_FLAGS OpenMP_Fortran_LIB_NAMES)
-- Could NOT find OpenMP (missing: OpenMP_Fortran_FOUND)
3 if i suppress, OPENMP and then run make i get error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MPI]
what does this mean... how can i resolve it
my bash file reads like this to set the environment
   source /opt/intel/compilers_and_libraries_2019/linux/bin/compilervars.sh intel64
   source /opt/intel/compilers_and_libraries_2019.4.243/linux/mkl/bin/mklvars.sh intel64 ilp64 mod
       export FCFLAGS=-i8
#    export CC=$(which mpicc)
#    export CXX=$(which mpicxx)
#     export FC=$(which mpif90)
export LD_LIBRARY_PATH="/opt/intel/lib"
export DYLD_LIBRARY_PATH="/opt/intel/lib"
export MANPATH="/opt/intel/man"
export PATH=/opt/intel/bin:$PATH
regards
vardaan
Steve_Lionel
The default integer size in Intel Fortran is 32 bits. You can use the "-integer-size 64" compiler option to change that, but I would much rather see you declare things as the proper size in the program.
sahgal__vardaan
sir, I tried using export FCFLAGS="-i8" in bash file but it did not work
also used FCFFLAGS="-i8"
it still shows 4 bit inter size. what is the right command. kindly tell me.
PrasanthD_intel
Hi Vardaan,
1) By default the integer size in fortran is 4Bytes(32bits). If you want to make it 64bit use -integer-size 64 flag while compiling as mentioned by Steve Lionel.
The command looks like
ifort -integer-size 64 filename.f90
Note : you can get the size in bytes using sizeof(var) function in fortran.
Please check this page for more info https://software.intel.com/en-us/fortran-compiler-developer-guide-and-reference-sizeof
2) If you are looking for the size of the folder in which Open MPI installed , then use this command to find the folder size in bytes.
du -s -B1 openMPI_Installed_Folder
 Alternately, if you are looking for the size of MPI_INT in OpenMPI it is 32bits . You can verify the size using sizeof(MPI_INT) in your fortran code.
3) Regarding this error , could you please provide your Cmake file so that we can debug the error.
4) Regarding the error #7002: Error in opening the compiled module file. Check INCLUDE paths , Please refer to the below link
https://software.intel.com/en-us/forums/intel-fortran-compiler/topic/731300
The problem may be incorrect arrangement of modules.
Prasanth
sahgal__vardaan
Prasanth sir
thank you for a detailed response. as desired cmakefile is attached. also attached is doc file containing details of the code.pl let me know if any other file is required
the code is question can be downloaded from      https://data.mendeley.com/datasets/3ptyfg2bmx/1
thanks and regards
vs
PrasanthD_intel
Hi Vardaan,
I have tried with cmake file you have provided and it works fine for me.
Maybe the problem is that the required intel fortran , impi and icc compilers were not sourced.
Please refer the Prerequisites/Before-you-begin sections of the below compilers:
 https://software.intel.com/en-us/get-started-with-mpi-for-linux
 https://software.intel.com/en-us/get-started-with-cpp-compiler-linux
 https://software.intel.com/en-us/get-started-with-fortran-compiler-linux
If you code do not require OpenMP , you can skip the section where it is failing by giving command as
cmake -DWITH_OPENMP=OFF <path>
The required environment variables will be set when you source the scripts, If you need to change please keep the previous path and do not override them.
eg : export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/your/custom/path/
Could you please specify your OpenMP version. You can get that by running this command
echo |cpp -fopenmp -dM |grep -i open
Prasanth
PrasanthD_intel
Is your issue resolved? Could you please confirm.
Reach out to us if you need any further help.
Prasanth
PrasanthD_intel
We are closing this thread considering the issue is resolved.
Please raise a new thread if you have any further queries.
Prasanth
