parallelizing array assignments
john-l-ditter
If I have a DO loop where the values of array B are assigned to array A in the form:
DO N=N1,N2
   A(:,N)=B(:,N)
ENDDO
Will parallelizing it in OpenMP like below work, or do i need to explicitly loop through the first index:
!$OMP PARALLEL DO
!$OMP& PRIVATE(N)
DO N=N1,N2
   A(:,N)=B(:,N)
ENDDO
What if, instead of an array B on the right-hand side, it is a scalar?
jimdempseyatthecove
Your code will work in parallel, even with scalar.
For small arrays you might want to avoid the parallel code. For large arrays, you might want to limit the number of threads to 2-4 as you will soon hit a memory bandwidth situation.
Jim Dempsey
Jim Dempsey
john-l-ditter
Thank you, Jim.
