passing arrays doesn't work
milenko1976
I have my module where I calculate apr1dsens,but when I call it in the main program I got some stupid values:
0.0000000E+00 0.0000000E+00 0.0000000E+00 0.0000000E+00 0.0000000E+00
0.0000000E+00 0.0000000E+00 2.7352493E-18 3.2547820E-17 -7.0026940E-16
9.2288178E-13 -5.7592910E-11 -1.8561423E-10 -5.2476946E-11 3.1348585E-12
-3.3206750E-11 -1.8173362E-11 -1.4415173E-12 -3.9798069E-12 2.4102038E-12
3.6711172E-12 9.3366406E-13 5.1709132E-14 2.2899610E-15 -5.3728867E-15
2.7020611E-15 3.0098718E-16 -1.4520080E-05 1.7714583E-05 -1.0487682E-05
-1.0487465E-06 0.0000000E+00 0.0000000E+00 0.0000000E+00 0.0000000E+00
0.0000000E+00 0.0000000E+00 1.6734045E-19 1.5395922E-18 -3.8514049E-17
This is part of the output.I am attaching the whole program.
The call to sensd2hmod_mod1 in ircg.for is inconsistent with the actual routine. You pass four arguments to a routine with only three, and it looks as if the second one shouldn't be there.
milenko1976
Thanks Steve.
Well the problem si even if I change this to sensd2hmod_mod1(iper,apr3dsens,apr4dsens) and compile it I get output:
0.0000000E+00 0.0000000E+00 3.9282067E-08 4.4769473E-07 1.6902050E-05
-1.3822162E-03 -1.7433049E-09 -1.5438827E-08 9.2458697E-07 -1.3776307E-04
-1.2786566E-02 -3.6022477E-02 -1.5723234E-02 4.8045099E-02 1.375854
0.6727987 0.1763481 0.1299756 -1.3305345E-02 -2.1294735E-02
-4.9546692E-03 -3.3784957E-04 -1.3261051E-05 1.7116079E-05 -1.0121098E-05
Again wrong values,the appropriate one are written in file 114.So something else is sisue.
mecej4
Your program has bugs, and persons writing code are expected to learn to use the tools provided by the compiler to detect bugs.
Compile with at least subscript checking turned on and run your code. You will see subscript overruns.
milenko1976
I wiill try with -CB.
Did you write this code? Your responses suggest that you don't understand what it does.
milenko1976
I have wrote one part of it,I know where the problem is now.
