29276 Discussions
passing command line argument as parameters
roddur
I have a routine to get 4 command line argument:
module chk_argumnt
CONTAINS
subroutine chk(x,y)
implicit none
integer::ac
real*4::x,y!,v_a,v_b,e_a,e_b
character(4)::cx,cy,atn1,atn2
! ac=command_argument_count()
write(*,*)command_argument_count()
call get_command_argument(1,cx)
call get_command_argument(2,cy)
call get_command_argument(3,atn1)
call get_command_argument(4,atn2)
read(cy,*)y
read(cx,*)x
write(*,*)atn1,cx,atn2,cy
write(*,*)"from module",x,y
end subroutine chk
end module chk_argumnt
now i want to use them in another routine to initialize variable/
parameters:
program main
use chk_argumnt
real*4::tx=x*10,ty=y*10
! real*4,parameter::tx=x*10,ty=y*10
call chk(x,y)
write(*,*) x
write(*,*) y
end program main
but i cannot do that. What my aim is to supply the main four
parameters from commandline. how can i do that?
roddur
sorry for doubleposting.....i dont know if i can delete thread.
TimP
Quoting - roddur
When you are logged in, you should have a Delete button below the thread.
PARAMETER means a compile time constant. The compiler ought to refuse to compile anything which attempts to store run-time data in a PARAMETER constant.
Izaak_Beekman
New Contributor II
Quoting - tim18
Using the protected attribute will cause variables to be read-only from outside the module (or scoping unit I think), i.e. within the module they may be modified, but to any programs which access the module via use association these ariables will behave as if they are parameters (i.e. they cannot appear on the left hand side of an assignment statement etc.).
I have attached a copy of a module I use to do exactly this: get command line arguments and options, as well as a few other things.
