29413 Discussions
performance of logical flags with bit functions or logical variables
clabra
I need use flag variables for intensive use in user defined types, but I'm not sure about the faster way for this. I'm considering two possibilities. The first one is use directly logical variables, as follow:
type node_t
logical(1), dimension(4) :: flag
end type
integer, parameter :: ACTIVE = 1
and the use is:
subroutine foo( node, ... )
type(node_t), intent(in) :: node
if( node%flag(ACTIVE) ) then
... do something ...
end if
end subroutine foo
The second possibility is use bit intrinsic function, with integer variables:
type node_t
integer(1) :: flag
end type
integer(1), parameter :: ACTIVE
with:
if( btest(node%flag,ACTIVE) ) then
end if
end subroutine foo
Someone can say something about the better way for this,
in order to obtain a good performance, I will really appreciated.
thanks
TimP
You would really have to test performance yourself. If you do a significant amount of other processing, and the code isn't vectorizable, it seems unlikely you could measure a performance difference between your proposals. For potentially vectorizable code, you might have to evaluate default logical data types, if you are willing to use more data space to gain speed.
