pfxlocaltime
vivekrao4
Compiling the code below, which calls pfxlocaltime, a POSIX extension, in both the main program and in the module, using just "ifort xtemp.f90",
module file_time_mod
implicit none
private
public :: foo
integer, private, parameter :: nia=9
contains
subroutine foo()
integer :: ierror,iatime(nia),isecnds
external pfxlocaltime
isecnds = 1
iatime = 0
call pfxlocaltime(isecnds,iatime,ierror)
print*,iatime
end subroutine foo
end module file_time_mod
program xpfx
use file_time_mod, only: foo
implicit none
integer, parameter :: nia = 9
integer :: i,isecnds,iatime(nia),ierror
isecnds = 1
iatime = 0
call pxflocaltime(isecnds,iatime,ierror)
print*,iatime
call foo()
end program xpfx
I get the error message
Intel Fortran Compiler for 32-bit applications, Version 9.1 Build 20060706Z Package ID: W_FC_C_9.1.028
Copyright (C) 1985-2006 Intel Corporation. All rights reserved.
Microsoft Incremental Linker Version 8.00.50727.42
Copyright (C) Microsoft Corporation. All rights reserved.
-out:xtemp.exe
-subsystem:console
xtemp.obj
xtemp.obj : error LNK2019: unresolved external symbol _PFXLOCALTIME referenced in function _FILE_TIME_MOD_mp_FOO
xtemp.exe : fatal error LNK1120: 1 unresolved externals
If I remove the module and the call to foo(), the program compiles and runs without error. I don't see why the call to pfxlocaltime should work from the main program but not from the module.
Vivek Rao
If you stare at the two calls long enough, it will come to you. Perhaps a careful examination of the error message will also help.
vivekrao4
I did look at the two calls before posting, but this time I finally see that I transposed letters. Sorry about that, Steve.
