29285 Discussions
pointer in namelist, but no compiler error?
j0e
I see in intel fortran and elsewhere that a pointer cannot be specified in a NAMELIST statement; however, when I do so anyway, no compiler errors occur. Furthermore, it seems to work just fine in that reading the namelist file updates the pointer and associated target as expected.
Given that it is not supposed to work, I won't use it, but why does it work at all (or have I misread something)?
cheers,
-joe
[fortran]module glob
   implicit none
   integer, parameter:: n = 10
   real(8), target:: x(n)
   real(8), pointer:: ptox1, ptox2
   namelist /test/ x, ptox1
   contains
   subroutine initialize ()
      ptox1 => x(1)
      ptox2 => x(2)
      return
   end subroutine initialize
end module glob
program pointertests
   use glob
   implicit none
   call initialize ()
   open(unit=1,file='test.dat',status='old')
   read(1,nml=test)
   close(unit=1)
   write(6,*) 'x: ', x(1:2)
   write(6,*) 'ptox1: ', ptox1
   write(6,*) 'ptox2: ', ptox2
   stop
end program pointertests[/fortran]
where test.data is:
[plain]&test
x(1:2) = 1.0, 2.0
ptox1 = 10.
/[/plain]
Steven_L_Intel1
This is legal in Fortran 2003. If you ask for F90 or F95 standards checking, it will complain.
