29342 Discussions
possible bug when transmitting arrays to subroutines
ojacquet
Could you please test the attached sample program that may highlight a bug when transmitting an array to a subroutine...
Thanks a lot,
Olivier
FortranFan
@ojacquet ,
The last 2 situations appear to indicate a bug in Intel Fortran compiler.
If your purchase terms allow, please submit a support request at Intel OSC: https://supporttickets.intel.com/?lang=en-US
Arjen_Markus
No, this is not a bug, but a very deliberate choice: the lower and upper bounds are not passed to subroutines or functions. Consider what would happen if you had a routine like this:
subroutine printit( array )
    real, dimension(:) :: array
    integer :: i
    do i = 1,size(array)
        write(*,*) i, array(i)
    enddo
end subroutine printit
This is a rather typical pattern: the index is assumed to start at 1 - as it will be in the vast majority of cases. If the (non-default) lower bound was passed to the subroutine, then ANY subroutine or function would have to be written in a fashion that takes care of such non-trivial bounds. That would be a big impact on existing code.
Arjen
ojacquet
I apologize if I do not understand your answer correctly.
I would have thought that the attached program should always give 1 and 2. However this is not the case and that intrigues me.
Here are the results obtained:
test 2D array of double precisions - lbound 0, ubound 0
direct write 1.00000000000000 2.00000000000000
write after transmission 1.00000000000000 2.00000000000000
lbound - ubound 1 2
test 2D array of type TYPE1 - lbound 0, ubound 0
lbound - ubound 1 2
test 2D array of type TYPE2 - lbound 1, ubound 1
lbound - ubound 1 2
test 2D array of type TYPE2 - lbound 0, ubound 0
write after transmission 0.000000000000000E+000 6.506773410276216E-317
lbound - ubound 1 2
test 1D array of type TYPE2 - lbound 0, ubound 1
write after transmission 6.506805030477550E-317 1.00000000000000
lbound - ubound 1 2
Do you observe the same thing as me?
It seems to me your answer does not justify what I observe...
Best regards.
Olivier
FortranFan
@ojacquet ,
ojacquet
This bug of Intel Fortran compiler is still present in the very last version...
Is it sill necessary to submit a support request to have the bug corrected?
I think it is not only for my personal profit, but for Intel and for all users...
Olivier
Barbara_P_Intel
Did you file a support request?  What is the case number so I can follow up?
I can file one, if you didn't.  Please let me know.
ojacquet
No I did not. I would appreciate if you could do that for me.
Olivier
Barbara_P_Intel
I filed bug report, CMPLRIL0-34513, on your behalf.  I'll keep you posted on its progress to a fix.
Arjen_Markus
Ah, my mistake :(. My reaction was triggered by your printing the lower and upper bounds only, but you found a completely different problem.
Barbara_P_Intel
This bug you reported is fixed in the current release of ifort, 2021.7.0. It's part of oneAPI 2022.3 that was released last week.
Give it a try!
