preprocessor directives for gfortran and Intel
Robinson__Donald
I help to develop a Fortran/C/C++ open-source project (open-fvs) that builds on Unix, MinGW and VisualStudio/Intel Fortran tool chains, based on cmake tools. I've been stumped by a recent Fortran preprocessor issue that seems like it should be simple. Equivalent issues in C work across the 3 tool chains. In the Visual Studio-Intel Fortran 12 environment  I need to call getpid(), which requires using "USE IFPORT". I would like the same code to be able to work across all environments, and preprocessors would seem to be the way to go. Assuming __GFORTRAN__ is defined in the gfortran situation and not in VS/Intel, something like this klunky example is what I have in mind:
!DEC$ IF DEFINED (__GFORTRAN__)
!DEC$ ELSE
      use ifport
!DEC$ ENDIF
The !DEC$ lines are ignored by gfortran, but USE IFPORT obviously isn't. I'd appreciate advice on how to create preprocessor directives that will work across the tool chains.
TimP
It doesn't seem imaginative, but I use the /fpp directives which are understood by both gfortran and ifort.
I've had customers who set up to use a separate gcc pre-processing step regardless of which fortran is involved.
gcc -E -traditional -x c  (or gfortran -E) to translate .F to .f.   On Windows, the preprocessed files must go in a new folder or be named .for.
JVanB
Valued Contributor II
Just create a file:
!DEC$ IF(.FALSE.)
module ifport
end module ifport
!DEC$ ENDIF
When you compile it with ifort, you get nothing; compile with others and you get an ifport module you may safely USE.
FortranFan
You could write your own interface for _getpid, thereby avoid IFPORT in Intel Fortran, and simply ignore the warning you'd get about shadowing an intrinsic in gfortran.
Steven_L_Intel1
Don't use the !DEC$ directives - as Tim hints, use #ifdef and add /fpp when compiling with Intel Fortran.
