I have old outputs using MS fortran 5.1 for DOS where fractions are printed without leading zeros, e.g. .45.
My IVF 9.1.034 prints with leading zeros, e.g. 0.45.
Is there a way for IVF to print without leading zeros (forautomated output comparisons)?
Thank you,
Yair
No, sorry. The Fortran standard makes the leading zero for fractions optional. Most implementations display it, but Microsoft's did not. This is not under user control.
To be portable you will have to write edit function that takes a real and format, write to internal record, remove potential leading zero, return string.
Jim
