29487 Discussions
problem about intel fortan compiler 12
caza
i have delete intel fortan compiler 12 with out uninstalation
so when i try to install it again and another old version, this message is appear
The Intel Composer XE 2011 Update 3 for Linux* is already installed.
If you want to reinstall the Intel Composer XE 2011 Update 3 for Linux*
please uninstall current version and run install script again.
how to uninstall it now
thank's in advance
Kevin_D_Intel
Generate a list of Intel Fortran Composer XE 2011 Update 3 RPMs using the following command:
rpm -qa | grep intel | grep 174
Save that list away somewhere in case it is needed.
Next, as root, remove all Intel Fortran Composer XE 2011 Update 3 related RPMs using the following command:
rpm -e --allmatches `rpm -qa | grep intel | grep 174`
Please NOTE: The use of back-single-quotes in the command above are significant. Be sure to include them.
Once that rpm command completes, then re-try the installation of Update 3 or different version.
Ron_Green
IF you did a non-root installation OR a non-RPM installation, you should also remove the intel/ directory created in your home directory:
rm -Rf ~/intel
ron
caza
thank you very much for your help
i remove all rpm - one: intel-compilerpro-common-174-12.0-3.noarch
when i do : rpm -e --allmatches `rpm -qa | grep intel | grep 174`
i found this :
[root@localhost]# rpm -qa | grep intel | grep 174
[root@localhost]# rpm -e --allmatches `rpm -qa | grep intel | grep 174`
erreur: %preun(intel-compilerpro-common-174-12.0-3.noarch) scriptlet failed, exit status 1
what i should do now
Kevin_D_Intel
Do you suffer the same error when trying to remove just that RPM with:
rpm -e intel-compilerpro-common-174-12.0-3.noarch
caza
yes i have the same problem
[root@localhost physolde]# rpm -e intel-compilerpro-common-174-12.0-3.noarch
Kevin_D_Intel
Ok, let's try this:
rpm --noscripts -e intel-compilerpro-common-174-12.0-3.noarch
