problem during multi-file IPO
rkbhai
I am trying to use /Qipo option along with other optimization flags. After several hours of compilation, it give me following error at the linking level.
IPO: performing multi-file optimizations
Link: error: problem during multi-file optimization compilation (code -1073741819)
is there a conflict with using /Qipo along with any other optimizations flags?
regards,
rajesh
One problem I know is if you try to specify the name of the object file... What options are you using?
rkbhai
I am usingfollowing flags:
/Zi /fast /Ob2 /QaxW /QxW /Qunroll4 /Qparallel /Qipo /Qscalar_rep
thanks,rajesh
I suggest submitting a test case to Intel Premier Support.
