29652 Discussions
problem of using global allocatable array
kashif10
I have a program test.f
PROGRAM test
use globalloc
IMPLICIT NONE
allocate(pop(mesh))
read(*,*)mesh
do i=1,mesh,1
read(*,*)pop(i)
end do
call peace()
end
that uses a module globalloc.f
module globalloc
double precision,allocatable,dimension(:) :: pop
integer mesh,i
end module globalloc
and uses a subroutine peace.f
subroutine peace()
use globalloc
implicit none
double precision, dimension(:),allocatable::gum
allocate(gum(mesh))
do i = 1,mesh,1
gum(i)=pop(i)
write (*,*) pop(i)
end do
end
when the input i give
mesh=5
pop(1)=2.0
pop(2)=3.0
pop(3)=4.0
pop(4)=5.0
pop(5)=6.0
the output is
2.00000000000000
3.00000000000000
4.00000000000000
5.00000000000000
1.39804067596061D-076
** Address Error **
please help me why it is not taking all values from module.
miu
Can allocate be used before specifying the size of Dimension? Is it necessary to replace the line of `allocate(pop(mesh))', and the line of `read(*,*)mesh' ?
