29641 Discussions
problem with 4+ dimension allocatable arrays and optimized code
avidard
Hi all,
I am experiencing some curious behavior when trying to allocate a 4 dimensional array. it happens on a snow leopard core 2 duo MBP with a 64 byte kernel, with the latest ifort (11.1 088) with an evaluation license.
(on a leopard with 32bit kernel and an older version of ifort, I did not manage to reproduce the problem)
I manage to reproduce the problem with the following simplistic program:
[bash]PROGRAM boulishgu
   IMPLICIT NONE
   REAL, DIMENSION(:,:,:,:), ALLOCATABLE :: t
   INTEGER :: ierr
   INTEGER :: i, j, k, l
   INTEGER, PARAMETER :: pi = 2, pj = 2, pk = 2, pl = 2
   ALLOCATE (t (pi, pj, pk, pl), STAT=ierr)
   PRINT*,'t allocated', ierr
   DO l = 1, pl
      DO k = 1, pk
         DO j = 1, pj
            DO i= 1, pi
               PRINT*, i, j, k, l
               t(i, j, k, l) = 2.*i
               PRINT*, t(i, j, k, l)
            END DO
         END DO
      END DO
   END DO
   PRINT*,'sum t',SUM(t)
   DEALLOCATE(t)
END PROGRAM boulishgu[/bash]
if I compile it with the -g flag only, everything is fine and I get my answer
However, if I use any optimization level whatsoever, the execution failed when trying to access any t(:,:,:,2) (I get an abort trap message).
the value of the dimensions pi, pj, pk does not seem to matter, as long as they are >= 2
If the array t is only 3 dimensional (or pl=1), everything is fine, for both -g and -On flags
any idea ?
thanks,
Arthur
Make sure that you are not using XCode 3.2.2. See here.
Ron_Green
it is the Xcode 3.2.2 problem. Runs fine for 11.1.088 under Xcode 3.2.1. Aborts for 11.1.088 under Xcode 3.2.2
ron
avidard
Thank you very much, that was the problem indeed.
Sorry I missed the fact that I was using Xcode 3.2.2
