problem with FindWindow
Jiri_P_
Hallo
I'm not able to compile this code.
program SEC_TEST
use ifwin
implicit none
character*(256) title
integer :: hwnd
hwnd = findwindow(null, title)
end program SEC_TEST
I always obtain the next error message:
Generic procedure reference has two or more specific procedure with the same type/rank/keyword signature. [FINDWINDOW]
Can anybody tell me why? I'm using IVF10.0.26 and VS2003.
Thanks Jiri
jimdempseyatthecove
Jiri,
The best way to go about solving these problems for yourself is to search the IVF include directory for the interface declarations. In user32.f90 (the module that creates user32.mod) you will find the declaration for FindWindow. To-wit:
INTERFACE FindWindow
FUNCTION FindWindow_G1( &
lpClassName, &
lpWindowName)
use ifwinty
integer(HANDLE) :: FindWindow_G1 ! HWND
!DEC$ ATTRIBUTES DEFAULT, STDCALL, DECORATE, ALIAS:'FindWindowA' :: FindWindow_G1
!DEC$ ATTRIBUTES REFERENCE, ALLOW_NULL :: lpClassName
character*(*) lpClassName ! LPCSTR lpClassName
!DEC$ ATTRIBUTES REFERENCE, ALLOW_NULL :: lpWindowName
character*(*) lpWindowName ! LPCSTR lpWindowName
END FUNCTION
FUNCTION FindWindow_G2( &
lpClassName, &
lpWindowName)
use ifwinty
integer(HANDLE) :: FindWindow_G2 ! HWND
!DEC$ ATTRIBUTES DEFAULT, STDCALL, DECORATE, ALIAS:'FindWindowA' :: FindWindow_G2
integer(LPVOID) lpClassName ! LPCSTR lpClassName
END FUNCTION
END INTERFACE
The 2nd template is the one you are attempting to call. When using the interfaces you will find that FORTRAN compilers do not promote variables with the same viggor as does C++.
I think you may find that if you change your code to
integer(HANDLE) :: hwnd
If that fails then also add/change
integer(LPVOID) :: myNULL
hwnd = findwindow(myNULL, title)
Jim Dempsey
Jiri_P_
Dear Jim
Thank you for your reply. It was good idea to look at user32.f90 for FindWindow interface declaration. I found out there is two functions in this interface. I used one of them (FindWindow_G1) and compilation was successful.
I would like to use "Save as" dialog in the console application.
The reason of using this function is that I try to find out hwnd of console because dialog appears behind the console and I can switch between dialog and console. This solved my problem only partly. Now I can't switch to console until save or cancel button is pressed but dialog still appears behind the console.
Today I have analyzed some other source codes and I found out next things:
1) ofn%hwndOwner = GETFOREGROUNDWINDOW() is sufficient and much more simpler smiley [:-)]
2) If there isn't any output to console (write, print, type) before calling dialog this dialog appears in front of console. But I need some output before.
Any suggestion?
Jiri,
You should not use FindWindow_G1 in your code. Unfortunately, there is an error in the declaration in the module that makes the generic reference ambiguous. I'll have that fixed in a future release. You can keep using the _G1 name for now, though I will agree that GetForegroundWindow() is a better choice.
I don't underatand your second question. If this is a console application, the console window should appear immediately even without any output.
Jiri_P_
Hallo Steve
Regaring my second question. There was a little misunderstanding. You are right. Console appears immediately after runing exe file. But after this when I try to open dialog "Save as" the placing of this dialog depends on whether there was any output to console before opening this dialog. If there was any output dialog "Save as" appears behind the console.If there wasn't any output dialog "Save as" appears in front the console.
Sorry for my English.
Jiri
Look at the sample Win32GetOpenFileName to see how to do this. You pass GetForegroundWindow() as hwndOwner.
Jiri_P_
Steve
Sorry but you still don't understand me. Using of GetForegroundWindow() as hwndOwner is clear for me.
Attached you can find GetOpenFileName sample with small modification. I added the 'read' statement befor calling GetOpenFileName function. If you start program and enter any whole number you can see that 'Open' dialog appears behind the console window. You must to use 'Start without Debugging' or run this exe file from comman line or some explorer. Because if youuse debug then 'Open' dialog appears normally in front of console window.
Sorry for confusing in previous post. Read statement is input to console not output.
It doesn't do that for me. When I build and run your program, using "Start without debugging", the filename browse window appears on top of the console window.
Jiri_P_
Steve, could you send me yourexe file please? I'll test it and if it will work correctly then I have probably problem with VS2003 or compiler.
I can't email EXE files, even ZIPped. I have attached it here.
Jiri_P_
Yes,zip isok. Thank you. I have tryed it and 'Open' dialog appeared behind the console.
Therefore I still don't understand where is the problem :-( I have done test on some other computer also and result is stil the same.
I'd be interested to have others try the program I attached. I see the same behavior whether I run it from Visual Studio or just double-click on the EXE. I am running Windows XP.
g_f_thomas
From Vista:
Console appears, no dialog, and Ctr C ing gives
forrtl: severe (24):end-of-file during read, unit -4, file CONIN$
etc
Doesn't matter whether 'run as admin' or in 'xp compatibility'.
However, the ivf sample runs just fine on 2-click :console behind dialog.
In vs 2005, run without debug: no go
In vs 2005 debug: runs fine
Gerry
Gerry, what do you mean by "no go"?
Interesting Vista results...
g_f_thomas
By 'no go' (slang)I meanit doesn't happen or work. What does happen is the console appears, stuff is written to it, and then it disappears,all in the blink of an eye.
Gerry
Gerry, did you build the program from source or just run my EXE from VS? The behavior you describe is odd.
g_f_thomas
Steve, it seems to behave as I would expect. With the exe you posted earlier all I did was 2-click it. Since that didn't do muchI went to the ivf samples folder and rebuilt the project in vs in both debug and release mode. Debugging both (yes, the debugger snivels about the absence of debug symbols but no matter) displayed the open dialog on top of the console. Ditto on 2-clicking the exes from explorer. Running the release in vs from debug/run without debugging behaved like the exe you posted earlier. Is this what is odd? It must be the weather or ...
Gerry
What I find odd is the behavior where the console window disappears instantly. I don't see how that would happen.
Les_Neilson
Valued Contributor II
Steve,
I ran your exe (also under Windows XP)
The console appeared, I entered a number, then the File Open dialog appeared. No problems here.
Les
g_f_thomas
Ditto on Vista, provided you enter a number when the console appears. However the source in the ivf samples folder doesn't expect keyboard input to kick start the app. Has something changed in the source for the posted exe over that generated by rebuilding the ivf samples source?
Gerry
Gerry, reread the thread. The EXE I posted was modified to prompt for input.
