problem with USE
roddur
in a old fixed format f77 routine, is it possible to use "USE" statement? I have a old routine, and a module just to pass name of directories:
[cpp]module parameters
	 character(25)::ASR_DIR='/home/rudra/Recursion/ASR/'
	character(28)::LMA_DIR='/home/rudra/Recursion/LMTO_A/'
	character(28)::LMB_DIR='/home/rudra/Recursion/LMTO_B/'
       	end module parameters
[/cpp]
in a f77 routine atompp as
[cpp]subroutine atompp(avw,clabl,kap2,lfree,lmx,lrel,nclass,nl,nsp,pp,
     .                  sigma,ves,vmtz,wsr,z)
	use parameters
...[/cpp]
while compiling, i am getting error,
ATOM/atompp.o: In function `atompp_':
ATOM/atompp.f:(.text+0x318): undefined reference to `parameters_mp_asr_dir_'
so whats wrong with this?
There's nothing wrong with the USE. The problem is that when linking, you have to supply the .o that resulted from compiling module "parameters".
roddur
thats what is strange! in makefile, .o file is present, but yet not linking!is it because any f90-f77 mismatch?
When you say f90-f77 mismatch, are you using two different compilers or are you applying the "f77" term to fixed-form source compiled with ifort? If two different compilers, that's not supported. If it's a mixture of fixed-form and free-form, that doesn't matter.
Perhaps using nm to examine the symbols in the .o would be enlightening, looking to see if anything similar to the missing symbol is defined.
roddur
i am using one compiler only.
how can i check .o files? this in not human readable...iam in linux
